Catalytic converter
Old Aug 31, 2003 | 05:04 AM
cobraq8's Avatar
02' C32 AMG
Catalytic converter
For those who have removed it, did you experience any malfunctions? Was there any black smoke accumulating on the exhaust tips/bumper? Was there any “check engine” warning lights? Because as I recall, I have replaced the exhaust system on my less sophisticated Mustang Cobra with non-cat exhaust and all the above signs were observed. I want to replace the rear cat with a straight flanged pipe to be used only on off road applications then reinstall the cat once done. By the way how much rear HP it accounts for when removed?
Old Aug 31, 2003 | 05:54 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
WHAT???
you sure your are not talking about the resonator?? I don't think there's any muffler out there that fits the C32 that doesn't have a cat converter.
Old Aug 31, 2003 | 07:26 AM
cobraq8's Avatar
02' C32 AMG
Sorry if I was not clear in phrasing my question. I meant removing the catalytic converter and placing a straight pipe in its place.
Old Aug 31, 2003 | 01:36 PM
Ronald's Avatar
Mercedes-Benz SL 55 AMG (R 230) and CLK 55 (W 209)
In Germany this would be illegal due to the amount of emissions and even tax evasion. Anyway, you would also have to send a false signal to the lamda-probes placed before and after the catalytic converter. Otherwise you'll get nothing but error messages.
May I ask why you are even thinking about doing this?
Ronald
Old Aug 31, 2003 | 01:52 PM
Bux's Avatar
Bux
G
i heard you can use steel tape on the sensors and tie them up or even better get this electric cutout valves flick a switch to go back and forth from open headers to stock exahust flow
vid of WRX with it installed
Old Aug 31, 2003 | 04:53 PM
99ITR_SC's Avatar
C32 AMG
Ronald
For poweR? For sound? For reasons that don't concern you?
Old Sep 1, 2003 | 12:32 AM
c32brabus's Avatar
i had two of the cats removed. the other two that are closer to the motor are more difficult to get to, so i never touched them. In place of the cats we put pipes and drilled holes in for the sensors to screw on. I havnt seen any check light yet... it been about 30kmiles.
you'll notice some drop in low end torque but on after about 2500 rpms it gets through the band faster and with a lot less effort. Also there's a harder and faster kick when you floor it and it downshifts.
Old Sep 1, 2003 | 02:02 AM
cobraq8's Avatar
02' C32 AMG
Thanks for the feed back every one. I will let you know how it goes
Old Sep 1, 2003 | 02:04 AM
pointman's Avatar
a car that can't do the throttle reset.
Dont do it... first youll fail inspection... sure youll get more hp... but after you cut out the cat... you cant get it serviced... the dealership BY LAW cannot let you leave without a cat cuz of emissions... but it might be different in your state, but i doubt it.
Old Sep 8, 2003 | 10:43 AM
Keyser_Soze's Avatar
C230 Komp Sedan - 2003
my $0.02
if you remove your cat your car will stink like poop! don't do it!!!!
Old Sep 9, 2003 | 04:50 AM
cobraq8's Avatar
02' C32 AMG
What do you mean??
Old Sep 10, 2003 | 01:02 PM
moomeh
Guest
Posts: n/a
more hp and stinking like poop vs stock hp and smelling good. it really is a tough decision. but then you add the laws on emissions and neither should be appealing. sure some laws are useless, but emission laws are here for a reason!
