Part # for brake caliper bolts?
EPC is throwing a certificate error for me (on two separate computers), and I've searched exhaustively here, so if anybody happens to know where I might be able to find this P#, it would be much appreciated.
Also, any recommendations for reverse screw extractors to pull out a stripped caliper bolt?
Are you looking for the caliper bolt that bolts it on to the knuckle? If you are looking for the skinny bolts that hold it together, they are not available as a spare part as they are not meant to be disassembled. Maybe you can source it direct from the manufacturer of the caliper.
Am I missing something? Do you not even have to touch those eight T50s to change the rotors/pads? Maybe I should search for a brake change DIY thread... color me embarrassed.
I need to change the rotors and pads, but I was derping on how to get the calipers off. Slapped myself a few times upside the head, regained my common sense, and figured it out
If you separated the torx bolts that holds the caliper halves together, you may have just messed up your calipers. Most people have trouble with them leaking after that.
Any tips on getting the T30 out that holds the rotor onto the hub? Hit it with PB Blaster and I've been trying to carefully loosen it, but it's near impossible to get any torque on it with the rotor spinning.
Use a hammer; you may need an "impact" to break it loose. Or try using an impact wrench on very low torque; careful not to strip it....
Lesson learned - don't use cheap *** rotors, even if your shop tells you they're the greatest thing since sliced bread. They were Zimmermans, if I'm not mistaken. Less than 40k miles and just over a year - the Akebono pads are still around 50%...
