Weird Engine noise, any ideas??
Les
Les
My m119 engine had an issue where one of the cam oiler tubes had broken inside the valve cover and resulted in a lifter running dry.
Im not sure if the m113k engine uses a similiar set up.
Does the sound increase with engine rpm?
It has a rhythmic ritt ritt to it, and as I increase rpm it gets faster. On the open road you cant hear it at all, although this is possibly because its doing it so fast you cant hear it. I did take the serpentine belt off and stil it made the noise, so not supercharger.
So it must be from the block. Couple of questions I have....
- How would I know if its the chain tensioner just by visual inspection?
- Is it a massive mission to get all the way to the timing chain? I am technically minded but not a fundi at this.
- How would I know if the chain has stretched?
- Obviously I will look at the guide rails etc, but are there any other giveaway signs that the rails are game over?
- If I open up the block and the chain has too much play in it, does that mean chain stretched or chain tensioner more than likely game over?
Your opinions are proving very valuable....
Les
