a/c compressor leaking out of pulley
Old Jul 13, 2013 | 01:51 PM
fleishman's Avatar
2002 C32 AMG
I noticed a bright green stripe around the a/c compressor pulley today. It appears that a very fine mist of what i assume is refrigerant has been leaking out by the front shaft. I searched but couldn't find this as a very common problem. A/c is nice and cold, for now. Could someone steer me in the right direction to diagnose and repair?
Attached Thumbnails a/c compressor leaking out of pulley-1373725741709.jpg   a/c compressor leaking out of pulley-1373725811704.jpg
Old Jul 13, 2013 | 03:09 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
Did you use a leak detectant..? Refrigerant evaporates once in comes in contact with the atmosphere.. Unless it's the compressor oil building up.
Old Jul 14, 2013 | 04:32 AM
Richardmozis's Avatar
E55 AMG
I have the same problem on my c55! The green stuff is a dye used to check for leaks and.... we both have leaks but cold ac. My ac compressor unit was replaced before I bought the car. Problem was that I bought the car during a cold Canadian winter..... and didn't use the ac.
Old Jul 14, 2013 | 07:53 AM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
Mine is doing that too, but it still blows cold.
Old Jul 14, 2013 | 07:57 AM
fleishman's Avatar
2002 C32 AMG
Interesting, i didn't add the leak detector so it has been in there. I didn't notice it leaking last summer. I scrubbed the spot on the frame clean so i can see if it returns.
Should i have the a/c charged?
I could be losing compressor oil too, it was pretty sludgy around the bottom hoses. How would i check that?
Old Jul 14, 2013 | 10:04 AM
WaveyKat's Avatar
Something Slow
MY Ac compressor died doesn't leak but when I turn the AC on I Can see the pulley trying to turn it looks like its sticking SMH.. my ac will blow cold then stop and blow hot air it makes a squeaking sound sometimes..
Old Aug 11, 2013 | 08:10 AM
fleishman's Avatar
2002 C32 AMG
Sounds like you can just replace the clutch.
Any advice on r&r for a compressor leak?
Old Feb 11, 2015 | 10:23 AM
afurkan's Avatar
2003 C320
Exclamation
Same problem on my 2003 C320.
Do I need to completely change the A/C Kompressor ?
