Supercharger pulley vs crank pulley (no tune)
Old Jul 29, 2013 | 11:29 PM
evavel7's Avatar
mgLipGD
First off I would like to say I have searched and searched and read and read some more on these damn pulleys, but I cant help but get confused
so basically what I would like to know is what is the better route to take on boost upgrades without an ecu tune. Perhaps maybe just an ecu tune only?
I always thought that just a sc pulley upgrade would be best, but what size? I am looking to stay simple bolt on DIY.
please share your experiences with the pulley upgrades and what setup you had and maybe what you wish you had done.
Thanks guys
Ev
Old Jul 30, 2013 | 12:04 AM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Thanks guys
Ev
If you want no tune, the easiest and best power add on would be the Eurocharged 65mm SC Pulley. Super easy to take On/Off and can be driven without a tune. If you go for the smaller 61mm SC pulley, I wouldn't advise it without a tune.
A crank pulley Overdrives your other pulleys and is much harder to install/remove.
http://www.eurocharged.com/products/mercedes-tuning/c-class/c32/pulleys/eurocharged-c32-slk-amg-supercharger-pulley-detail
Old Jul 30, 2013 | 12:05 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
There are lots of combinations but if you want to keep things simple and DYI, get a 65mm or 62mm SC pulley. You must get a tune. Also if you are in a worm climate, get cooling mods (highly recommended). All of it (with the exception of a tune) is a DYI and is available from Eurocharged.com. There are also other vendors as well as the used market. The only pulley that does not require a tune and cooling (but is still recommended) is the 178mm crank pulley.
Old Jul 30, 2013 | 12:17 AM
2002 C32, 2012 S550
I thought the 65mm SC pulley was about equivalent to a 178 Crank pulley in terms of boost?
Old Jul 30, 2013 | 12:23 AM
Lenin's Avatar
It's equivalent to a 181mm crank pulley. And the 62/61mm SC pulley is equivalent to a 185mm pulley. There was a time when Evosport used to make a 168mm crank pulley but that is currently unavailable.
Old Jul 30, 2013 | 12:33 AM
Lenin's Avatar
Another possibility is if you have access to a good machine shop, to machine the OEM SC pulley to around 66.5mm. You can get the OEM pulleys now for around $300 and this way you are keeping things conservative and should not need a tune.
Old Jul 30, 2013 | 01:18 AM
precisionmike's Avatar
2003 C32
I have a Eurocharged SC pulley and tune, and the car is amazing.
Old Jul 30, 2013 | 08:44 AM
evavel7's Avatar
mgLipGD
well on that note... anybody selling a 65mm pulley?
P.s. is there a thread with a list of vendors and what not?
