C32 Quad Ram Air Intake!!
If you dont mind going ghetto you should try a Hood Scoop and customize your intake for a huge increase of air!
Wow, is the factory intake that hard to see? there still there working properly with K&N's in them, plus a 3rd filter is on the back with 2 extra lines running to it..
That was the whole point to this, to try and leave the OEM stuff there, the only thing that's different is the 2 extra lines going to the back, and they can be changed to black water lines to blend even more!! The inspection station wouldn't blink an eye with this as opposed to it being all hacked up with Big aftermarket tubes and covers missing.
Regarding how ugly my intake looks vs. your creation, I think the forum made their opinion known in this thread. Yes, it's not as cheap, but it's 100% bolt on and does not require hacking any OEM parts. BTW, what's your 1/4 mile time?
Another blind or stupid? There is filter material in y-pipe(gray material behind grill), so those small tubes are filtered also. I dont know good that filter is, but there is somekind filter anyway.
A very simple mod to understand how that works and clear pictures. Have to wonder these comments, and to draw conclusions...If this was offended by someone's mind, then I'm sorry
Play it cool and were good thx.
I saw the filter "material" in the y- pipe. I just think its not the same as a Green or K&N filters with oil or some advantage over to use your son´s soccer sock as a filter.
An 1" hose add paralel to std 2" is not an 50% increase.
1x1x3,14(area) = 3,14
2x2x3.14 = 12,56
3x3x3.14 = 28,26
You´ve got 15.7 inches of area.
A bit over the half of an 3" pipe.
I dunno how to calculate squareinch area, so i just calculated the inches in the metric way.
The answer is talking for itself.
However, adding hoses to inject air is not a bad idea, but just adding them in an random place could be devastating, not saying you did.
But saying it to open peoples mind.
Where do i want to add them then?
Well, in an tight radiusbend, on the inner-radius. if one got an 'release' of the boundarylayer (of the air) one can inject air to equalize the airpressure, and the air will follow the bend better.
You gain flow at high speeds in this way, where normally the turbulence gets out of control and actually restrics the pipe.
sorry.. got technical there
