Aftermarket NAV/bluetooth.... etc units
Old Jan 10, 2014 | 04:02 PM
Saaboteur's Avatar
eclectic assortment of cars
Duncan: Cool. I think I will follow your progress (as long as you keep us posted!) and maybe not rush into buying a used COMAND unit. I had no idea about Crux before, so I Googled and am impressed to find they have a wired unit. I really don't trust the PAC stuff to work instantaneously as it seems to rely on IR beams.
Can I PM you to ask other details?
Old Jan 10, 2014 | 05:42 PM
New Benzo's Avatar
C55 AMG
It would be great whom ever is doing this upgrade to supply some pictures of the installation.
Old Jan 10, 2014 | 08:49 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
FWIW i use the PAC units all the time and have never had a problem. I even got the steering wheel controls working in my clk with their units. I have a alpine 7" touch display in my c32 that works great also. I think the stock speakers sound great paired with a sub and it is much easier than running all new wires.
Old Jan 11, 2014 | 04:12 AM
JCurtis's Avatar
A32 AMG
If you want a lot of the aftermarket functions and programming, but you want the OE look, check out www.dynavin.com
Old Jan 11, 2014 | 08:20 PM
Duncan64's Avatar
C55 AMG
I'll take pics for you guys... I'm having a hell of a time with the backup camera at the moment though...
Old Jan 13, 2014 | 08:46 AM
Duncan64's Avatar
C55 AMG
Some pics of my App Radio install...
Run the new amp's power wire from the battery. First pull the plug out from inside the car, then run the wire from the battery to the inside.
Inside the car by the passenger footwell. An 8 guage wire fits nicely through there.
Then just run it along side the car to the back under the carpet. There is a cavity where all the wires are run for the car. Tuck it in there...
Here's the wires i used for the speakers from the back of the HU to the amp in the back.
16 Gauge twisted wires bought like this... I wanted colors so i can keep track of positive / negative and specific speakers. So i would run one white loom to the back, then wire 1 speaker up at the front, then at the back to keep it simple.
Old Jan 13, 2014 | 08:53 AM
  #32
Duncan64's Avatar
C55 AMG
Sure feel free to PM me if you want. I must warn you that i am no professional though I'll keep this thread updated with my progress and maybe help out that way so you can see whats involved in doing this.
I already put my App Radio in and forgot to take pics of that, and i'm not going to take that thing out again... its a mess and it was really hard to push it back into place because of all the adapters / wiring harnesses etc. that makes space a premium back there. Not to mention the heavy duty RCA cables i used for the amp that dont bend that easily.
Old Jan 13, 2014 | 09:06 AM
  #33
Duncan64's Avatar
C55 AMG
This is the HU I'm replacing by the way model BB0510 ...
When i unhooked everything i saw that I dont have speaker wires in the Block A connector. Its a give-away you have fiber optics running the speakers.
This is the wiring harness i bought that plugs right into the factory harness pulled from the OEM HU. This harness also plugs into the CRUX module that drives the steering wheel controls. You can kind of see it in one of these pics.
[/QUOTE]
Old Jan 13, 2014 | 02:25 PM
  #34
blacksage's Avatar
2006 C55
Good stuff! How long did the install take?
Old Jan 13, 2014 | 02:37 PM
  #35
Duncan64's Avatar
C55 AMG
haha its still going on ... going on a week now. I dont use my car much so i can leave it in the garage while i work on it every now and then. I dont have a ton of free time so i work a bit, then leave it till later... or i'm waiting for a part to come in etc. I wouldn't be a good judge of timing on this project.
Like right now... i just completed everything, and realized the amp turn on doesn't turn the amp on, because i paid for a wiring diagram online through startek and believed it without testing... for some reason it doesn't work. So now i have to run the amp turn on from my head-unit and run one wire to the back again.
Old Jan 14, 2014 | 12:46 AM
  #36
shaun.barnard's Avatar
2012 C63 AMG Coupe
Hi guys interesting stuff, thanks for sharing im sure it will help many other members.
Do any of you have the part number for the fibre optic plug that goes into the OE CDC. Mine was bypassed when I bought the car and now I decided to take my CDC in for repairs, I did a test and there is power on the power plug but the CDC does not respond at all. So now ill need the optic fibre plug (the black box that the 2 orange optic "wires" go in to) when I get the CDC to work.
Old Jan 14, 2014 | 08:41 AM
  #37
Duncan64's Avatar
C55 AMG
Shaun i'm sorry i'm lost as to where exactly you are looking for this plug? Is it at the back in the stock amp?
Anyway, here's my App Radio 3 installed. The sound quality is not as good as the Comand unit was, but hopefully its either because i have to tweak it on the HU or adjust the gain on my amp... or its because i used a crappy amp, or its because i used the same channel for the center front speaker and the sub in the back. EIther way, i'm going to play with those things and report back - it all kind of just sounds like there's a lack of high pitch and bass... everything sounds kind of dull and flat. No real bass and no high tones.
Old Jan 14, 2014 | 10:21 AM
  #38
2012 C63 AMG Coupe
Wow that looks very neat.
I mean the black plug that the two orange fiber optics go into that plugs into the stock cd changer in the glove box.
Old Jan 14, 2014 | 10:53 AM
  #39
Saaboteur's Avatar
I'm interested in hearing about the functionality of the steering wheel controls - okay, I take it you can't really 'surf' the App Radio with the stock controls, it wasn't built for that - but volume obviously works, how about moving between tracks and such?
Old Jan 14, 2014 | 11:18 AM
  #40
Duncan64's Avatar
C55 AMG
yeah i'll check that out for you... I was very frustrated for a while because my USB connector didn't launch all the apps on my phone for some reason... luckily i found this video because it doesn't say to do this in the user manual at all.
Old Jan 14, 2014 | 01:22 PM
  #41
Duncan64's Avatar
C55 AMG
this is the connection to the cd changer... hope this helps.
Old Jan 14, 2014 | 01:52 PM
  #42
2012 C63 AMG Coupe
Yes thanks that's the one.
Old Jan 14, 2014 | 09:22 PM
  #43
Duncan64's Avatar
C55 AMG
I played the songs on my iphone today and I could easily change tracks by using the left up/down buttons on the steering wheel.
Old Jan 16, 2014 | 12:45 AM
  #44
2012 C63 AMG Coupe
Took my CDC in today for repairs and ordered that plug from the agents so hopefully ill have that working at least for now.
Duncan, ive read that the CDC can play MP3's, can you confirm that for me please?
Old Jan 16, 2014 | 06:24 AM
  #45
2012 C63 AMG Coupe
I found the answer, the MC 3520 model CDC can play mp3's and the MC 3330 can not play mp3's and guess which one I have.............the 3330, isn't Murphy just a miserable old *******.lol
Old Jan 16, 2014 | 07:07 AM
  #46
Duncan64's Avatar
C55 AMG
I'll check my model too but I've never tried it.
Old Jan 16, 2014 | 07:11 AM
  #47
Duncan64's Avatar
C55 AMG
Also, I played pandora through Bluetooth streaming with the phone in my pocket and it even skipped tracks if I used the steering wheel controls. I'm happy about that!
Old Feb 11, 2014 | 12:54 PM
  #48
2012 C63 AMG Coupe
Hi Duncan, sorry one more question, I had the cdc fixed and now im waiting for the optic fibre plug, what I need to know, if you can remember, where does the red head go and the white head in the plug. Don't know if im explaining myself properly but if you look at the end of the orange fibre optics wires there is one red and one white now im afraid that when I get my plug I wont know which one goes on top and which one at the bottom.
Old Feb 11, 2014 | 12:56 PM
  #49
2012 C63 AMG Coupe
I see on the pic of your plug, the last pic in post 41, that there is an in and out arrow, I would presume that the red goes in and the white comes out of the cdc but not sure?
Old Feb 12, 2014 | 08:35 AM
  #50
Duncan64's Avatar
C55 AMG
i'm not sure, i didn't pull them out to tell you. It wont hurt to just put it in and see if it plays. You'll know to switch them if it doesn't.
