Haven't been around in awhile, need some tire/maintenance advice!
Note that I've driven the C32 only about 12k miles since 2008, so these will last me awhile (shuttle bus to work does wonders!)
Supercharger bearing got replaced earlier this year as well as the idler pulley. Now it looks like my secondary air pump is losing it again. I'm having my local mechanic see if it's the relay vs. the pump and I found the old thread with the DIY pump as well as the link to the ebay guy that will re-manufacture your pump for like $110. This is pretty much a perpetual problem for everyone even after the TSB "fix" huh?
To be safe, check the size of the 335 tires and post here.
If the question is, can you put your 335i wheels with winter tires on your C55? the answer is NO. The bolt pattern is different and your wheels won't fit. If the question is, can you take the tires off your 335i rims and mount them on your C55 rims the answer is maybe and we would need to know the size of the tires.
As for size, I'm probably going to order today and 235/40 is the max we can fit up front without fender rolling right? Or is that already going to be too close given that I have 10mm spacers?
As far as size, I don't use spacers and run 225/40 in the front and 255/35 in the rear. My car is very low on Bilstein PSS9 and 235/40 will be rubbing. Your situation may be different. Check your current clearance. And in general, you want the front and the rear to be more or less in line with each other. Otherwise for drag racing everyone is always looking for skinny tires in the front and wide tires in the rear.
Check thread: https://mbworld.org/forums/c32-amg-c...out-there.html
My personal experience:
Toyo: really soft, crazy grip dry weather, horrible in rain, wear out fast.
Pirelli PZero, relatively soft, great grip, also in wet, wear out reasonably fast.
Bridgestone Ptenza: great grip, relative hard tires, last long, great in the rain. BEST!
Kumho: Under-appreciated brand, great value for the money.
Depends when and how you drive your car, and what you are looking for in the tires..
