C32 AMG General Maintenance *picture heavy*
Just got done replacing my leaky valve covers, with fresh oem gaskets. As well as finally changing out the original spark plugs, wires, and air filters.
Check out the pictures, the valve covers were completely soaked.. and the spark plugs were rusty as hell.. shame whoever owned this car before me.
I replaced everything with Bosch OEM wires, bosch oem iridium plugs, gaskets from the dealer, and genuine mann air filters.
Yes, the car ran 10 years with the same plugs, and air filters.
The difference is very apparent.. the car was sluggish, didn't want to accelerate, and was getting poor fuel economy at best. Now the fuel economy has picked up significantly, and throttle response is much crisper.
I have only owned the car for about 8 months and have put a fair share of work into it.
So far I have changed the:
intercooler pump
alternator
valve cover gaskets
spark plugs
spark plug wires
air filters
engine oil
coolant
power steering fluid
brake fluid
I love this car but it was definitely neglected in its previous life. Driven hard and put away wet. About the only issues I have now are my right headlamp is out, and replacing the bulb doesn't do anything. I believe the electronic ballast is bad, and they are expensive. Anyone have any alternatives without changing the OEM headlamps? (they are too nice to change)
Valve train looks good for almost 90k miles as well!
I was also very surprised at the clean condition of the valve train.
I have been using Liqui Molly 0W-40, it is a good synthetic oil also made in Germany and meets MB specs... a bit cheaper than Mobil 1 and has never done me wrong.
My Porsche friends use it, and I've switched to it as well.
BTW, those plugs you pulled out look like crap! Good job you replaced them.
I have access to lots of european wholesalers that retail customers don't.
Shoot me a text vince ill get you a deal. I paid less than 50 bucks for my oil filter and 8 liters of liqui moly
I also have the same problem with my headlight but it is my left one.
I took it to Mercedes and they said i need a new HID Control Unit & Head Light Unit. ($3,342)
Have you found a way to fix this cheaper?
Marcus, of those items on your list, the valve cover gaskets and spark plugs will be the easiest. Probably should do plug wires at the same time too. You may need the special spark plug removal tool, otherwise, cut open a 17mm angled box end wrench and good to go.
The engine mounts and trans mount will be next most difficult, and the rear main seal the most difficult. For the rear main seal, it's probably just a $10-20 part, but to get at it you need the transmission out (or the engine out, I guess).
Yeah one of my coil pack clips did in fact break. I was very careful. They dont like to be taken on and off.
I saw your DIY, and actually when it broke that's the first thing I thought about. Its on my to do list.
@Marcus.. leaky rear main? Bad news man. The labour to perform this job is immensive and not something that can be done easily DIY. As saab mentioned the engine and transmission need to be seperated in order to perform this repair.
Keep an eye on it yourself!
