I'm desperate c32
Old Oct 13, 2013 | 01:55 PM
super-amg's Avatar
c32 amg
I'm desperate c32
I am very disappointed, I have installed all parts of performance, but it's 106 miles to the quarter mile, just 13.1, please tell me what can decrease r the trap speed, I want to achieve 109 or 110 miles, please tell me to do
thanks
Old Oct 13, 2013 | 04:28 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Drag radials and lighter weight wheels.
Old Oct 13, 2013 | 04:38 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
thanks
Post all your mods, data from logging and your last slip. It can be any number of things, including you and the way you launch the car.
Old Oct 14, 2013 | 02:04 AM
gwin's Avatar
C32 AMG, 997, Mustang '66
Have you stripped the car? FRP/Carbon bonnet/boot, removed all carpets, light weight wheels, replaced seats with racing one piece seats, removed back seat and all audio equipment and the entire dash?
Old Oct 17, 2013 | 08:35 AM
super-amg's Avatar
c32 amg
my mods are
pump jonsonm
SC 62MM pulley eurocharged
tune eurocharge
manifolds , and DCAI needwings
shorty headers eurocharged
magnetor cables and NGK bkr6eix-11
alcohol-water injection
resonador and cat , delete
a big HEAT EXCHAN
NeedsWings Intercooler Fluid Isolation Kit
with all that mod , only 105 mille sometimes 106 , somebody tell me what i need to check
Old Oct 17, 2013 | 10:34 AM
Lenin's Avatar
my mods are
pump jonsonm
tune eurocharge
a big HEAT EXCHAN
The mod list looks good. How about the time slip? If you want any help, it's important to understand where you are losing the time (at launch, mid or top end).
Old Oct 17, 2013 | 10:48 AM
super-amg's Avatar
c32 amg
i think my problem it a top end , i need more mille , please tell me what i need to check , the spark plug?? or wat
Old Oct 17, 2013 | 11:18 AM
Lenin's Avatar
Your problem is the first 1/8 of a mile. To finish at 12.9 sec. your 330ft should be 5.45 and it is 5.55. Your 1/8 time should be 8.3 @85 MPH and your are at 8.5@82.6 MPH.
What kind of gas are you using? Do you get good gas in DR? Did you get a tune for your specific mods or is it a generic tune?
Old Oct 17, 2013 | 11:33 AM
super-amg's Avatar
c32 amg
yeah we have goog gas here , but too spen , but the normal gas have around 89 octane , y told jerry the octane of my gas here , and he made a tune for this octane , when i put a 100 octane gas i feel the car more slow
i have a OEM heat range spark plug , i was think buy a 1 range more cold
super-amg's Avatar
c32 amg
Old Oct 17, 2013 | 11:38 AM
Lenin's Avatar
I run OEM plugs.
Old Oct 17, 2013 | 12:08 PM
NeedsWings's Avatar
01 slk320, 01 e55, 02 c32, 06 ml500
you are loosing traction on the line, you need either slicks or drag radials to cut a 1.8 60ft and it will all come together
super-amg's Avatar
c32 amg
I run OEM plugs.
so , what you recomend me , for improve my trap speed , and me 1/8
Old Oct 17, 2013 | 12:38 PM
Lenin's Avatar
Even if you get drag radials and lighter weight wheels, you still should be faster than what you are running. Look at other people's time slips and you will see that even with 2.0sec 60ft you should still get you 12.9 or faster. 1.8 sec 60ft can get you to 12.7x or better. Only data logging can tell for sure what is wrong. I would be looking at the timing, boost, IATs and AFRs. Somehow the ECU is not giving you the full power.
Rob (Needswings), is my thinking not right here? You are the real expert.
Old Oct 17, 2013 | 03:28 PM
raf12690's Avatar
c32 amg
Yeah he definitely is not pulling like he should. I had less mods and a 2.002 60ft and had a 1/8 trap of 87+ and 1/4 mile trap at 110+. I think that he might have something holding him back, like clogged fuel filter etc. I told him he needs to datalog to really see the problem.
Super AMG. Look into getting a zeitronix zt2 wideband system with some type of display. Dashdaq is one of the better options but there are some others for better price.
http://www.ebay.com/itm/like/200827242064?lpid=82
Old Oct 17, 2013 | 03:30 PM
raf12690's Avatar
c32 amg
Or just use the EC one, although it's not as fast and AFR isn't logged you will at least see timing, boost, etc.
Old Oct 17, 2013 | 07:27 PM
super-amg's Avatar
c32 amg
exactly you have the same 60ft mine , and you run 12.7 with 110 milles , i was think my engine have problem or something like that
i have a boost gauge aem , and the car boost 18 psi , in the morning 19 psi
Old Oct 17, 2013 | 07:38 PM
super-amg's Avatar
c32 amg
Old Oct 18, 2013 | 07:19 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Everyone here has missed the magical question, what tires are you running on?
Next, pump the fronts up to 45psi, and drop the rears to 30-22. Do not go below 20 psi for safety.
You'r 0-60ft time stink, to run into the 12's.
Buy some good tires, think Bridgstoe PP's, nitto's, or ANY tire with a treadware LOWER than 160.
Have fun
Old Oct 18, 2013 | 09:48 PM
Newzchspy's Avatar
PLAID
Have fun
In addition to DRs, look at reaction time? Driver needs some mods too!
Old Oct 20, 2013 | 12:22 AM
moosejaw's Avatar
none
What's your elevation?
Are you in the hills?
Old Oct 20, 2013 | 01:16 PM
super-amg's Avatar
c32 amg
no , im front the sea , seach autódromo mobil 1 , and see
other think i bougt a new sparkplugs 1 heat more cold , i have ik20 imgoing to install ik22 for see
Old Nov 17, 2013 | 08:18 PM
1slosnake's Avatar
Mustang
Reaction time doesn't affect the 1/4 mile time at all just to let you know.
Old Nov 18, 2013 | 03:07 AM
C3Duece's Avatar
2002 C32AMG
Old Nov 18, 2013 | 03:12 AM
C3Duece's Avatar
2002 C32AMG
I think this is your problem....low timing from 89oct fuel Makes sense that the car is slower on 100oct running the 89oct tune. You need EC to send you a hotter tune for the 100oct and you'll be in the 12's
