Does it need a better fix....
Old Nov 13, 2003 | 04:44 PM
jcanabal's Avatar
2006 SLK 55 AMG
I had a nail in this tire after the Pittsburg event......I took it to the shop and re mounted.....unfortunatelly couldn't go to VIR so never tested it. Now that the comp tires are off (to use the winter ones)I noticed this..... Does it need a beeter fix? Is it save for next years events?
Thanks!
Old Nov 13, 2003 | 04:46 PM
jcanabal's Avatar
2006 SLK 55 AMG
next
Old Nov 13, 2003 | 04:51 PM
jcanabal's Avatar
2006 SLK 55 AMG
another...from inside
Old Nov 13, 2003 | 04:53 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Technically, any repair to a tire voids its speed rating.
I've patched several race tires on my Acura (max. spd. 115 or so) and never had any problems. Going 130+ may be a different story.
In any case, if you're going to try to continue using the tire, I'd have it dismounted, and patched from the inside, rather than have it plugged. A plug could be "thrown" at high speeds - not a pretty picture.
You may want to post a similar question for Luke in the Tires/Wheels forum.
OOPS . . . while I was replying, you were posting 3rd picture. Looks like you did patch from inside.
Old Nov 13, 2003 | 06:21 PM
hammyoni's Avatar
C32
It does look like it was correclty patched from the inside. I have run patched tires before, but I would never have 100% confidence in them. AutoX, yes, 130+ at a track, no thanks.
Old Nov 13, 2003 | 08:21 PM
CarlssonCRS's Avatar
r171
those tires look really worn already....
Old Nov 13, 2003 | 10:00 PM
hammyoni's Avatar
C32
I believe they are R compound tires...they look prime for some track time
Old Nov 15, 2003 | 11:09 AM
Franco's Avatar
2002 C32
Personally I would not take a chance. A blow out at high speeds can be more costly than replacing that tire or the set of tires.
Old Nov 15, 2003 | 05:45 PM
Dr Chill's Avatar
Porcelain Bus
No way would I trust my life on that tire at speeds in excess or 120.
Old Nov 15, 2003 | 06:02 PM
awiner's Avatar
2003 CL55 AMG
Junk the tire and get a new one.
