YAW, it sucks hard.
Old Dec 16, 2013 | 01:48 PM
gwin's Avatar
C32 AMG, 997, Mustang '66
YAW, it sucks hard.
This is a compounding problem, one day I was driving home and i took a light dip to the left and my doors unlocked. I thought It was some radio freq disruption, made a mental note since it was hard to come up with any real case.
Then today driving home my ESP malfunction came on after a bump in the road, and the car went into limp mode. No other warning lights,just the error message.
Combined with my low throttle jerks I started putting the pieces together, after doing some research it's either the pedal sensor or the YAW sensor or a combination of both.
I couldn't replicate the error again to get the error code up to read it, so I just ordered a used YAW sensor anyway since it's not much.
Grrr.
Old Dec 17, 2013 | 09:01 AM
macbryanie's Avatar
Porsche 2004 911
Thats most likely tranny jerk, best to look into a glycol test and change radiator to behr if you have the valeo. Even with EC TCU tune the jerk happens but no so much as before. 2003 TCU's have this issue less.
Old Dec 17, 2013 | 10:38 AM
Saaboteur's Avatar
eclectic assortment of cars
Could it be as simple as an old battery? Always worth checking the simple stuff before you get into more expensive issues.
Old Dec 17, 2013 | 12:16 PM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
Ok, really newbie question: how do I properly check a battery for condition at home?
Might be the cause of some of my electrical gremlins too
Old Dec 17, 2013 | 04:49 PM
macbryanie's Avatar
Porsche 2004 911
You can check the voltage on the comand. There is a post on it. Its something along the lines of AUX then 1+3 mute together brings up back door menu.
Old Dec 17, 2013 | 05:03 PM
gwin's Avatar
Thanks, . Good point on the battery, I've overlooked it because I don't really have much electrical symptoms at the moment. I'll give it a check.
Old Dec 17, 2013 | 07:30 PM
Marine Blue's Avatar
2002 C32 AMG
Battery would have been my first guess too.
I would also check for loose connections.
Old Dec 17, 2013 | 07:57 PM
gwin's Avatar
My groin is pretty loosely connected too. seems to swing which way to Sunday
Old Dec 18, 2013 | 12:41 AM
gwin's Avatar
Checked battery is fine. After years of working with cars I didnt give me signs it was a battery issue. but ruled it out anyway. YAW/pedal sensor on the way!
Also received my CM30 today will change it during the holidays.
