Evosport EVO
how is the longevity of the C32 with these performance modifications, i have 27k miles now, but may not get around to installing them until around 35k(+
) miles. is it still healthy and will the C32 still last long, because this is my daily driver (i will be driving about 10, maybe 11 thousand miles a year). also, should i look into the aftercooler upgrade for longevity? to my knowledge, the overdrive pulleys come with the intercooler resorvoir upgrade, is that correct?i'll probably get an eisenmann race 83mm round too.
a question, how much will the Evosport pullies and ECU cost, and how much can i expect to pay total with installation? i have been browsing the boards a bit before i picked up my C32 and have observed that Evosport and Vadim have had quite some success with their C32 components - i assume Evosport is the best route to go. how does the Evosport setup compare to the RENNtech setup, with realizing that the RENNtech will be paying a lot for name. is its performance actually worth the money?
oh yeah, and is the SL55 intake hard to get or install? can i just get it from my dealer without an Sl55 VIN, or do i need to get an SL55 VIN? i have read it is $420, i'm not exactly a DIY guy and don't want to mess anything up so is it still a good mod for the money - it does not affect longevity realy does it? how about the E55 throttle body?
lastly, sorry for the long message - which of these parts will void my warranty. if it is voided, will it just be the engine warranty, or will COMAND still be covered, because i have heard several issues with COMAND. also which mods would you guys do in successive order, as i don't have too much $$ right now? pullies and ecu should probably done about the same time, i suppose.
sorry for the long message. thanks, i'd appreciate any help and info or opinions you guys have.
also, if i added the Sl55 intake and E55 throttle body, how much RWHP and RWTQ can i expect? how about with race gas, say 100 octane?
thanks!
Kevin
i have about 1500 miles, no problems~
with just the stage I, my dyno came out to be 340rwhp and 330ft-lbs of torque. that is with the chip and pulley alone. i have not had a chance to dyno my stage II yet, but i will post result as soon as i get on the dyno.
i have my car serviced at a local dealership for service A. the guys doesn't even know i have modded my engine except for my exhaust system. and... i did alota of research before i did my upgrade... renntech only runs on 93 octane... which is useless in Cali... unless you want to add octane booster everytime you fill up.
the mods will NOT void your warrenty unless they can prove that the failure is caused by the modification.
any further questions?
Jerry
Most likely you would not have problems with the minor mods, but its a risk you have to know and be willing take to play the mod game. I don't care how much someone tells you the mods are safe, because in the end if you screw something up, they wont be there to pay the bills.
Coupe of points though:
1. The ECU is invisible to the dealer - they cannot tell it was flashed.
2. You simply have to trust in the parts that you buy. You are right that you are somewhat on your own. As such, you don't want to be the first one with the mods and you want to be sure that the company that is selling you the parts has really tested them to make sure they will not blow your motor.
Brad
Modifying the exhaust (cat-back) does not do much for hp; at least not in a positive direction... We found through testing that removing the rear muffler completely only yields 1hp. Removing the resonator was not helpful, until combined with headers.
Thanks,
Ben
I would like it if we could do the cat back, then add the headers at a later time if wanted. One last opinon, Id like something like the stock C32 tips, more oval than the pictured SS tips. Please keep us updated.
I really want a quad exhaust. But I don't want to loose any power.
Would your solution be any different than the ones that silva and the others did. Is it basically just a bypass and then cutting out the bumper. That is great for the looks but I really want something like what one of the new clk55 guys got done at amg. It looks like a quad through and through from where it originates.
The only problem is I am in boston but I would ship my car if it was really worth it. In my opinion this car would look simply awesome with 4 amg oval tips perhaps a little staggered like the sl55.
Accomplice8 - no hijack taken. i think about the exhaust/ecu, it would be best to have pullies as well since the ecu is tuned for the pullies.
SilvaC32 - your car is AWESOME. i love it, and your engine must be very powerful. i admire your C32. was the stage I dyno on pump gas, if so, where are you located (i.e. in Cali, weak 91 oct). thanks for your firsthand insight, so you think its worthwhile mods :p so no problems yet, how does it idle and is it as streetable/is it like stock when you're not on the throttle? thanks again, please keep us posted with your mod progression, very nice car.
s4iscool - i share your concern, that is my main fear of engine mods since the Merc is stock supercharged at near 1bar, which is quite a bit IMO. that's the only thing that's holding me back from whipping out the cash right now, i want to see when people have more miles on the mods, how reliable the car is. that's why i'm thinking of the aftercooler options, as seen on the Evosport C32 at SEMA. i see your point very clearly.
otoupalik - thanks for your insight. can the dealer tell the car has aftermarket pullies? also, how much would the Evosport aftercooler options help for reliability? yes, i am waiting a bit to see how the mods hold up after more miles, because this will be my daily driver. thanks.
mach430 - thanks for the info. do you know if a catback system would in any way hurt performance figures. i had a uuc system u on my m3, and i lost some low-end torque. also, have you heard the eisenmann race on the C32, if so how does it sound? how does it compare to supersprint's new (upcoming) system? does RBTech or MKB make one yet? thanks.
btw, is evosport going to make an intake? if so, i would be more interested in their intake than the SL55 most likely. any other C32 performance parts coming out, power wise? thank you!
Yes - exhaust is a go!
We have headers now. The H-Pipe (with or without cats) will be ready soon, and the Supersprint mufflers for the C32 specific will be here in Jan. We will also do a quad if we can get at least 10 people interested.
Here is a pic of one of the 2 tips from SS:
Brad
How about a header, resonator, muffler package?
Jason
