C55 cranks but won't start - fuel issue? - need help quick
Does this sound right? I need someone on the forum who has some mechanical and electrical knowledge on the W203 chassis to chime in. I told them to hold off, but I can't keep them waiting long, so I need some advice. Who knows what this SAM thing is? Is it all electrical or anything mechanical that they are talking about? What are the rear fuel pump relays they are talking about? Doesn't sound like the fuel pump in the tank is involved, which I thought was probably the issue, but apparently not.
Does $2100 sound like a ripoff? Once I know what the SAM and rear fuel pump relays, I'll have a better idea of the cost I was quoted. Is this something simple to fix? I am a bit mechanically inclined, is this something I could do with the right tools?
Need advise ASAP, and thank you for any help!
Daniel
I would think that if the techs at the dealer hooked the car up to Star diagnostics, it could diagnose the CPS? Not sure though, I haven't had first hand experience with the factory diagnostic tools.
What is the SAM unit? What does the acronym S-A-M stand for? Where is it located? Would the computer diagnostic specifically point at the SAM unit if it went bad?
What and where are the "rear fuel pump relays"? I've never heard of any car having "rear" fuel pump relays...and even if it does, and even if they went bad, where is this $2100 repair cost come from? Does the SAM unit and rear fuel pump relays that expensive, or are they that hard to get to that labor is that expensive? That quote sounds ridiculous to me.
How could a Mercedes with only 74,000 miles get enough corrosion on the SAM to make it go bad? Chevrolets aren't that unreliable! I can't help but have the feeling that I'm getting screwed by the dealership.
Thanks for any advice.
Daniel
Les
Yes the SAM unit is expensive to replace, but I don't know about $2100.... dealers always mark it up big time.
Did you ever figure out the problem? If not:
Crank Position Sensor from rmeuropean.com = $45, throw in maybe some wiper blades or something else cheap to go over that $50 mark and get free shipping. Regardless of whether it is this or not, you WILL have to do this at some point (they are pretty much guaranteed to fail), probably before you get to 100k miles (I did mine around 85k or so).
And as far the dealer, there is a reason it's called the STEALERship. If anything, go to an Indy that knows how to work on German cars, much cheaper. Or if it is the SAM, you can replace that yourself. It's behind the driver's side rear tire in the trunk, just pull back the liner.
Good luck
