H&R FSB Install Problem
Did anyone else run into this problem?
You should also note that the H&R bar has 2 bolt holes on either side, I think to make it adjustable? If I remember correctly, I had to use the hole towards the front of my car, but I'm really not sure. It may make a difference of where your bar is located, but if you've got the bolt holes for the subframe brackets lined up you shouldn't have a problem. But a quick couple of tips:
1) slide the bar onto the links, put the nuts on but don't tighten them just yet
2) line up the subframe brackets and tighten those bolts first. This will line up the bar where it needs to be.
3) now you can use an 18mm wrench and can't remember the size torx bit to tighten the links. I found that the sway bar link bolt actually spins so what MB did is put a torx hole on the end of the bolt, so you have to hold the nut with a wrench and spin the bolt the opposite direction at the same time to tighten it. It's a bit of a PITA, but that's what you've gotta do
Contacting H&R today....
I am noticing that your sway bar brackets are a lot different than mine too. My brackets and bolts are larger and they aren't torx, they are 13mm hex bolts. I can't remember how close my PS lines were when I installed it, but I didn't seem to have an issue.
To be continued.
-edit-
Brackets look to be correct, will check the numbers when I get home. H&R says the part numbers needed are A 203 323 (11 and 12) 40
As far as the PS line bracket being bent, not really sure. I'm pretty busy this week, otherwise I'd jack it up and take a look at mine. I'll see if I can find some time.
thanks
Pete
