Hi there, I have a question for you guys. I have a 2002 C32 AMG. I bought it for 10K and it was a pretty sweet ride all until a mechanic (and im not getting into the legals of it) put a small amount of rock and dirt into the oil filter housing. Shes knocking pretty hard and although I am sueing this f*cker I want to cheaply as possible either fix the engine or should I not even bother and sell the parts off of it. Think the engine is salvageable with a rebuild or would buying a used engine be a better and cheaper choice? If I decide to part her out, think you guys would see a need for parts and maybe make some of my money back? Thanks for you answers and feedback and I a mechanically inclined person so engine rebuild for me wouldnt be a big issue. Also, whats the path that debris would be taking, into the heads or into the engine?
tw2
close
- Join DateAug 2011
- LocationNew Zealand
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:288 Times in 236 Posts
How/why did they put dirt into the housing? You need to strip it down to determine what has actually happened.
Oil goes everywhere so if there was debris in the housing after the filtration then it could potentially score all the bearings, crank and camshafts ie new engine. From a pure fixing point of view, if that had happened a second hand engine would be ideal. Must be a few crashed C32's around. Otherwise my preference is always to rebuild *if* possible since you know what you are getting, second hand - who knows.
Im a technician working in the oil patch in Northern Alberta / BC, Canada, I gave my C32 to this mechanic shop O/O to fix things he said he would take care of and he tried ripping me off so I got in a ruckus with him, he kept my keys, I had to leave and get the cops involved and when I went back my engine sounded like a 2 cylinder diesel :-(. Court didnt work out well cause a car can "break down" anytime and my lawyer lost the fracking cup of sand and gravel that was taken out during an oil change.
Thats it in a nutshell. I ended up buying a used engine with 70k on it and will install it when I get on days off. Is it easier to haul the engine through the top on these models or through the bottom? And is there a place where I can get an engine rebuild kit so I can take the scorn engine, rebuild it and perhaps crank some juice out of it? Im also interested in knowing if the cylinders are sleeved or integral. Thanks for your help.
C230 Mulac
close
Dude, this sounds like a mess, sorry to hear about all that!
If I were you, I'd go ahead and take the time to get some aftermarket cams and a few other things to power up the engine since it's already out of the engine bay before you put it back in.
I dont have the engine out yet, im still working away from home for another week and im trying to get everything lined up for when I get back. I was hoping for insight as to take the engine from the top or bottom, does anyone know the fastest/easiest way? Im not familiar with the Mercedes engine removal tactics whether its easier from the bottom or top, I would like to get some feedback on that subject. As well if I could get feedback on knowing if the cylinders are sleeved as well and as to find a place for engine rebuild kits that would be helpful, ive looked but couldnt find anything.
As for pulling the engine, through the top would be easiest or take the front off and pull it out that way. Can't help with the other parts.
