Pulled trigger on eBay shorty headers!
Bought the C55 eBay shorty headers this past July but didn't install them until now due to cooler weather in Plano. I was able to pick them up locally in Carrolton, inspect them, and negotiate a lower price, less $500 post tax. Based on the previous header post here I guess there are similar to AMS type headers. Took about4-5hrs in to install most time spent removing older headers. After install the new headers, I realized the collector was off angle and there was no way the down pipe/first cats flange was going to line up. It was off by 45*. I called up Top Speed Pro1 to verify they gave me the wrong ones and was able to exchange for the correct ones. They gave me MB#2 which fits E55 vs MB#1 for C55.
Once corrected, stock heads had one pair of thin metal gaskets per cylinder (16) so make sure those come off before installing the one piece gasket. Installation is easier due to more clearance due to less bulk of the stock manifolds.
So initial impressions: startup sounded a tiny bit more aggressive and slightly more refined. Normal driving appeared normal with no perceptible advantage or change. Going WOT on the highway appears to be most noticeable in a nice gain. Maybe ECU adapt will make it better? Doesn't appear to be a 30HP gain which my seat of the pants would detect. Maybe 10-12HP on the top end but that is just an educated guess (subjective). I already have a resonator and secondary cat delete. I measured inner diameter cylinder and collector opening and the are larger compared to stock. Measurements in pix. Just wanted to share my findings. Is it worth it????
BTW, the build quality is decent but don't have anything to compare to like the Kleeman or my SVO Mustang ceramic coated headers. Also, the pix are of the incorrect ones but the correct headers are the same EXCEPT the collector point straight down, not at 45 angle.
If I remember correctly, a stock C55 dynos around 298whp and 301wtq? With my Kleemann and no cats or res to stock mufflers, I pulled 328whp and 372wtq on the dyno. So just guestimating you with shorties and still primary cats, 10-12hp is probably accurate, but you won't notice a major difference until you tune it!
My whp should be higher but what's hurting me now is the intake. I need to upgrade it.
While the design and quality is better, I have seen the merge collector of Kleemanns... not pretty.
BTW, would my money spin clockwise or counter-clockwise in a New Zealand toilet?
Are you going to repair them, buy different ones, go back to stock?
And for the 55 guys, I still stand by my previous comments regarding Kleemann.
Those cheap china made headers cost around a $100 if that to make. Cheap materials and cheap labor. The grade of metal is good for intercooler piping. Heat from an engine is too much and weight of the factory cat is too much. The design is poor. Very little manifold volume increase. Anybody that says they gained power from these needs to do a back to back dyno. I am would bet they only make around 10hp tops!
