C55 overheating fan issue
Talked to my tuner and he mentioned that I have a low fan speed (comes on with a/c) and a high speed fan which is supposed to come on to cool the engine down. Both of these have relays and that it sounds like that is my issue.
So has this happened to anyone else? Not necessarily just the need for a new high speed fan relay but being told the ecu controls the fan and ecu alone? They didn't mention anything about a fan relay.
I talked to the service guy at MB and he seems like a straight up guy and I'm not stupid when it comes to cars but its just frustrating that MB would say this when its not even the issue. I will confirm tomorrow when my tuner takes a look at it with me but a new ecu and fan relay are completely opposite sides of the spectrum.
I appreciate any input guys thanks!
?? the MB tech could not diagnose whether or not the sensor is operating correctly ??
I'd try another more qualified shop.
Went to peters (c230mulac) this morning and tested out a new relay, fan still didn't turn on when needed. Checked the wires going to the fan (4 total combined a power, grd, high speed, low speed) and they all seem/look to be in working order. We used his voltmeter to check for power and it's there, just not getting the message to the fan. We also tried the same thing on his wires and got the same reading as mine so we ruled that out. If were working downstream from the relays, those wires were next, after that is the fan control module which seems to be attached to the fan itself. I also read that to test if the fan wires/module are out disconnect the coolant temp sensor and turn the car on, the fan should turn on full blast as a fail safe to protect the engine from overheating. I just tried that now and fan didn't come on. Any input?
Step 1, we tried switching the relay, didn't work.
Step 2, we unplugged temp sensor and turned car on. The temp gauge just stayed down at the bottom. When car is turned on cold, it heats up to operating temperature normally. I would think the sensor is okay as it seems to be reading temperature. If it were bad I would think the gauge would be acting funny. Too much of a coincidence for it to only be heating up during idle and not while driving to be the sensor.
Engine temp sensor = coolant temp sensor, they are the same item
Step 3, with the voltmeter set to voltage, red wire is hot, brown wire is ground, the other two I'm not sure what they are, must be low and high speed control. Readings taken with key in position 2 with engine off (Jake am I remembering that correctly?).
Red to brown - ~12V
White to brown - ~12V
Green to brown - ~0-0.003V
We took the same voltage readings on my harness and got the same values, so we know that the wire harness running to the fan is receiving power and none of the wires are broken upstream of that.
You can't officially buy the fan module separate of the fan assembly, however I have been able to find an aftermarket module but not sure how reliable it is. That is, if in fact it is the fan module.
However, like the others said, it may not be a bad idea to just swap the sensor and see if that fixes it. It is important to note when my water pump was going bad I had the exact same symptoms, the only difference is that I got the "coolant visit workshop" message on the dash each time it started to overheat; and sometimes it would overheat when at lower speeds around 10-20 mph, not just idle.
If you can turn on the fan remotely then I would think it could be the source of the signal, ie the sensor.
Just sayin,experts where are you.
Just sayin
As far as the water pump that could be the case, but I actually don't recall whether or not my pump was leaking...maybe it's that I caught it early enough and the pump had not entirely failed. In any case, it's worth mentioning I did see some sort of fluid below everything on top of the belly pan when Jake came over but we were thinking it's because it had been raining. But we didn't actually check to see if the fluid was water or coolant
Is the reservoir empty?
The fan turns when triggered via STAR system. That means the fan motor is working, the relays are working since I would guess STAR communicates with the fan via relays, the temp censor is working since the "overheating" message comes up. But the system doesn't work together under normal conditions. Is that a good summary?
Just sayin
http://www.rmeuropean.com/Part-Numbe...MTfu92pWA.aspx
I'm worried about buying the cheaper versions off ebay so should I stick with an OEM replacement for this part? Has anyone had to replace their cooling fan before?
The indy also told me that when the fan is replaced it has to be programmed to the car?? They called the dealership and asked them and dealer said they have the only machine that can program the fan to my car? So does anyone know if this is true or not? Any MB techs out there can shed some light? I will be able to swap the fan out on 24 jan but im hoping its just plug and go. Thanks
