Comand system
Old Jan 10, 2015 | 07:23 AM
limahls's Avatar
C63s Edition 1
Comand system
Good day all.
I have a C55Amg, I'm having trouble with the Comand system. Does anyone have the manual for the comand system as I did not receive it when I received the car. At this moment. The comand unit won't turn off. So the music is on constantly as well.
Please help?
Thank you in advance
Old Jan 10, 2015 | 10:14 AM
TonyLuvsJazz's Avatar
2012 E350 Sport 4matic
Post Command System Download Manual
Hello. I am a new MB owner and have only had my car for three days. The COMMAND system is quite in-depth. I went to the MB USA site and downloaded the pdf file for my car so that I could read it on my laptop. In my 2012 E350, I have to remove the key from the ignition to completely turn the COMMAND system off. Hope this helps. Best Regards. Here's the link I used:
http://www.mbusa.com/mercedes/servic...owners_manuals
Old Jan 10, 2015 | 01:50 PM
limahls's Avatar
C63s Edition 1
comand system
Hi
Thank you for the prompt reply.
Pulling the key out the ignition is how it always worked. Now I don't know what happened. Thank you for the link. I'll get the respective manual and hope it shows how to reset the system.
Limahl
Old Feb 22, 2015 | 02:02 PM
limahls's Avatar
C63s Edition 1
Good day all
I trust you're well.
I have a c 55 amg. The car has developed a terrible shudder.. mostly at 2000rpm. Throughout the first 4 gears. The whole car shudders quite badly.
Any ideas what could be wrong?
Thank you
Limahl
Old Feb 22, 2015 | 02:03 PM
limahls's Avatar
C63s Edition 1
terrible shudder
Good day all
I trust you're well.*
Thank you
Limahl
Old Feb 22, 2015 | 04:13 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Check for glycol contamination. Not too common in C55's but very common inW203s. C55 did come with Valeo radiators that were prone to leaking.
Old Feb 23, 2015 | 12:59 AM
limahls's Avatar
C63s Edition 1
Good day
Thank you for the prompt response...
How do I rid the problem of glycol contamination?
Limahl
Old Feb 24, 2015 | 11:31 PM
kjb55's Avatar
I would recommend a glycol test for the trans fluid immediately. If the text is positive for glycol. You need to replace the radiator. And flush the transmission and hope that the trans hasn't been damaged.
Old Feb 25, 2015 | 01:41 PM
limahls's Avatar
C63s Edition 1
Thank you
I have sent the car in, they say it's the engine and transmission mounts. However, I have asked them to test for glycol contamination.
Will let you know what happens
Thanks again
Limahl
Old Mar 5, 2015 | 02:38 PM
limahls's Avatar
C63s Edition 1
COMAMD system
Good day all
the COMAMD system in my car is acting up. It's practically stuck in a loop. It keeps asking to "insert navigations dvd". When I put it in it says "rebooting". It goes off and comes back on but says "please insert navigations dvd" and reboots and keeps going on like that. The radio and shuttle doesn't even work now... I had to pull out the fuse for the command system else it will stay on and keep doing the above.
Any ideas?
Thank you
Limahl
Old Mar 18, 2015 | 09:45 PM
JonMBZ's Avatar
06 C55, 09 E350
get it replaced I had to replace my dvd drive on my old C55 and my current c55 needs it again. I am sure they are getting to their life expectancy. Check out http://www.fastoem.com/ for a cheap replacement and ask them about your issue they are very knowledgeable about our command system.
Old Mar 19, 2015 | 02:03 AM
limahls's Avatar
C63s Edition 1
Good day
Thank you for the response.
I will check out their site. Are they in SA?
Many thanks
Limahl
