C32 SHUTS OFF WHEN FLOORED
Old Aug 17, 2015 | 12:09 AM
C32izm's Avatar
C32 amg
What's up guys my 02 32 recently started shutting off when I floor the pedal. The car will drive smoothly but as soon as I go to floor it it cuts right off. Starts back up fine and runs but the same problem keeps occurring. Recently changed the cps I'm not sure what this is about. Any advice ?
Old Aug 17, 2015 | 02:57 AM
Dollos's Avatar
Mercedes C32
Get the car read with SDS. Have you noticed that it happens only on the Kickdown switch? my money is on the MAF or the Pedal Assembly maybe???
Old Aug 17, 2015 | 03:58 AM
C32izm's Avatar
C32 amg
Yea when i hit the kickdown switch is cuts off. What's the best way of cleaning the maf?
Old Aug 17, 2015 | 04:00 AM
Dollos's Avatar
Mercedes C32
if ur sayin it happens only on the kickdown switch then the pedal is prob the culprit, but
SDS will tell you exactly whether its MAF or Pedal. Now i have my money on the pedal....
Old Aug 17, 2015 | 04:02 AM
C32izm's Avatar
C32 amg
When I push the pedal to the floor. I'm not sure if it's the kick down switch
Old Aug 17, 2015 | 04:15 AM
Dollos's Avatar
Mercedes C32
Lol u need to test properly bru.... happ only on kickdown or also on Before kickdown...
Old Aug 17, 2015 | 10:48 PM
C32izm's Avatar
C32 amg
On the kickdown on wot it cuts off, cel comes on. Start the car again drive it for a few minutes cel goes away. Then on kick down again same thing happens again. Car gives a hard time starting I have to hold the key.
Old Aug 18, 2015 | 02:43 AM
Dollos's Avatar
Mercedes C32
I could be wrong but now that you mentioned you have a hard startup as well, i would think this might have something to do with fueling.
As i mentioned before i would first hook up to atleast a scanner of some sort to get the codes for the CEL.
But if you cant get hold of one then maybe start with the small things first like the fuel filter which most guys ignore on service intervals... and since hard start and WOT require fuel id say Fuel filter first using the KISS formula...
Old Aug 18, 2015 | 02:27 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Just an Fyi. C32 doesn't have a MAF. I would also check the fueling situation.
Old Aug 18, 2015 | 02:40 PM
Dollos's Avatar
Mercedes C32
Eish, thanks for the correction Lenin, we have MAP sensors. i think i had my diesel on my mind when i wrote MAF.
Old Aug 19, 2015 | 01:38 PM
slomofo's Avatar
02 C32 AMG
Most likely an open in the pedal assembly. When the car senses the open at WOT, it shuts it down until restart. I would have a reliable shop pull codes and see if there are any accelerator pedal faults. I have had this happen in two different MB cars.
Old Aug 26, 2015 | 02:30 PM
Sickooli's Avatar
E250 cdi
exact same thing happened to me , changed the pedal and works perfect.
Old Sep 8, 2015 | 03:26 AM
C32izm's Avatar
C32 amg
What do you mean an open in the pedal? How can I check this ?
Old Sep 10, 2015 | 01:33 AM
MX5's Avatar
MX5
C32 plus some other vehicles
Temporary solution - don't floor it LOL
Dunno bout yours but flooring it in mine is only gonna lead to jailtime hehe
Old Sep 10, 2015 | 03:58 PM
mbguy949's Avatar
2006 C55, 2008 E63
what brand cps sensor did you replace it with, it is not uncommon to get a bad one, id replace it with a bosch sensor.
Old Sep 11, 2015 | 04:56 AM
Dollos's Avatar
Mercedes C32
Guy do yourself a world of a favour and get the codes read first ... dont change anything untill you do
