anyone have a diy 32 amg power steering pump install
remove the power steering reservoir first, theres one E10 bolt up top and a C clip at the pump inlet.
take a punch and depending if your belt tensioner has a center E10 on the pulley (old style) or 17mm fixed nut under the pulley (new style) release the tension and lock the tensioner with the punch or a small pin.
remove the belt from your pump.
usually one bolt on the backside of the pump, E12 remove it first, a ratcheting 10mm wrench can come in handy here.
remove the two front E12's last.
installation is reverse of removal. start all three bolts in the pump first before tightening them.
