2005 C55 lower mesh grills
Old Dec 29, 2015 | 11:19 AM
Jbarsness's Avatar
Mercedes C55
I am looking for the right and left mesh grills around the fog lights.
Old Dec 30, 2015 | 01:35 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Pelican parts or agents. However agents are expensive. Check Ebay as well. Might wana buy the clips while you at it.
Old Dec 30, 2015 | 09:06 AM
Jbarsness's Avatar
Mercedes C55
Does any one know what years and models will interchange?
Old Jan 7, 2016 | 09:17 AM
Jbarsness's Avatar
Mercedes C55
Hey guys if everybody can offer up any other places to find the lower grills. Or any other models that they will interchange was just that one every good luck and I knew to owning a Mercedes. Thanks for any information
Old Jan 7, 2016 | 10:30 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
clk55 03+ and c55 are the same bumper as far as I know. Where have you looked? We are going to do the foot work for you.
Old Jan 7, 2016 | 10:37 AM
Jbarsness's Avatar
Mercedes C55
I've looked at eBay and searched all over the Internet, I'm not sure if I'm calling it the correct name. I just bought this car 2 weeks ago and the guy that I bought it from says all it's no problem to find them. Love the car but it just does not look complete missing both sides. From what I've read very common for them to fall off.
Old Jan 7, 2016 | 12:13 PM
blacksage's Avatar
2006 C55
This thing?
http://www.ebay.com/itm/Mercedes-Gen...0AAOSwoydWiaer
Old Jan 8, 2016 | 04:55 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Blacksage has the correct part there. Just head over to Pelican parts, check under W203 C55 AMG 2004-2006 model and look under bumper parts for the front. You should find it somewhere. They are fog lamp grills, lower bumper grills, whatever you wana call it from those two, you should find it. Buy the new clips from the agents whilst you at it. Usually the front section of the clip breaks off if you don't remove it using a tiny flat blade screw driver. It may click when inserted but without that small tab its not really safe in there.
Old Jan 8, 2016 | 01:00 PM
Jbarsness's Avatar
Mercedes C55
From what I'm finding out it's not quite that simple I've been chatting with a guy on ebay who has Ones for a w203 that are not correct to the C 55 New ones are $275 a piece through Mercedes
Old Jan 8, 2016 | 04:19 PM
insame1's Avatar
so none of these are the correct ones? http://www.ebay.com/sch/?_from=R40&_...All-Categories
Old Jan 8, 2016 | 06:26 PM
Jbarsness's Avatar
Mercedes C55
So far from what I'm finding yes none of them will work the proper ones I through a eBay dealer is $250 each
Old Jan 8, 2016 | 11:38 PM
Naugamanator's Avatar
2005 C55
Mercedes part numbers below. And yes, they're $$$.
2038850653 right
2038850753 left
http://www.mbpartsworld.com/p/Merced...038850753.html
This guy might still have his:
https://mbworld.org/forums/exterior-...ml#post6644321
Old Jan 15, 2016 | 08:59 AM
Jbarsness's Avatar
Mercedes C55
Thank you sir, it helps having the correct part numbers
Old Jan 16, 2016 | 01:21 PM
K3nD's Avatar
2013 C63 Coupe P31
I've in the market for one right one as well. But holy cow, at $120 a piece, ill just use my old and dented one. Too bad no one makes a aftermarket version.
Old Jan 17, 2016 | 12:26 AM
Jbarsness's Avatar
Mercedes C55
Where did you find the right ones for $120?
Old Jan 17, 2016 | 06:20 PM
K3nD's Avatar
2013 C63 Coupe P31
It's all over eBay. Just search for w209 front bumper mesh. Here's one - http://m.ebay.com/itm/262095743952
Old Jan 18, 2016 | 01:32 PM
2005 C55
Please be careful here - although the C55 has a W209 bumper, the CLK driving lights are oval, and the C55 driving lights are round. Therefore you must match the part numbers, not just the model number.
Old Jan 19, 2016 | 04:59 AM
Jbarsness's Avatar
Mercedes C55
That's what I have found as well, I'll get the part numbers from mercedes and post them
Old Jan 19, 2016 | 08:07 AM
insame1's Avatar
so kit looks like part numbers are the same or this is not the correct picture.
http://www.pelicanparts.com/More_Inf...-885-17-53-M22
this is the correct one but you wil h ave to pony up for it
https://www.ecstuning.com/ES1735864/...S.ShoppingFeed
Old Jan 19, 2016 | 03:11 PM
2005 C55
got yer part number right here
Ummmm.. post #12??
If there is any question, go here to find all the exterior front bumper-related part numbers for the C55.
http://www.mbpartsworld.com/showAsse...rimLevel=20610
Old Jan 20, 2016 | 09:11 AM
insame1's Avatar
just posted that link because it is the least expensive one I found.
