C32 TRANNY NO ENGAGEMENT
Old Feb 4, 2016 | 03:06 PM
C32izm's Avatar
C32 amg
I was driving my 03 32 one day everything was fine. I parked it up, tried to go for a ride and the transmission didn't want to engage at all. After messing with it for a couple days i noticed it only engages when cold and when it warms up theres absolutely no engagement in any gear.
ANY IDEAS OF WHAT COULD OF WENT WRONG??
Old Feb 4, 2016 | 06:50 PM
cm60k's Avatar
It could be bad speed sensor(that attaches to conductor plate), or some oil sneaks to your TCU, or low oil level..?!?!
prefer to diagnose the car first, codes will help to narrow the issue..!
ZAYED,,
Old Feb 4, 2016 | 07:22 PM
Morphh's Avatar
C32 amg
ZAYED,,
Sounds like conductor plate in the trans
Old Feb 4, 2016 | 10:43 PM
C32izm's Avatar
C32 amg
ZAYED,,
MANAGED TO RUN A SCAN THE CODES THAT CAME UP ARE :
- P0730 incorrect gear ratio
-P0715 input/turbine speed sensor circuit
-P0123 throttle/pedal sensor/switch A circuit high input
Old Feb 4, 2016 | 10:44 PM
C32izm's Avatar
C32 amg
How can i go about verifying the conductor plate
Old Feb 5, 2016 | 03:19 AM
cm60k's Avatar
When you reset the system, are these "3" codes, appeared again..??
ZAYED,,
Old Feb 5, 2016 | 08:00 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
how old is your battery?
Old Feb 5, 2016 | 03:33 PM
C32izm's Avatar
C32 amg
ZAYED,,
they did not
Old Feb 5, 2016 | 03:34 PM
C32izm's Avatar
C32 amg
I'm not sure i haven't changed it, i picked up the car not too long ago
Old Feb 5, 2016 | 03:36 PM
C32izm's Avatar
C32 amg
I'm not sure i haven't changed it. i picked up the car not too long ago
Old Feb 6, 2016 | 02:01 AM
cm60k's Avatar
You have to clear the codes first,,
if any of them still appears, then you have to replace the damage item( that causes the issue)..!!
ZAYED,,
Old Feb 6, 2016 | 08:50 AM
Morphh's Avatar
C32 amg
ZAYED,,
U have 2 problems conductor plate in the trans and gas pedal assembley has to get replaced
