Post Evosport Stage I dyno
Old Mar 11, 2004 | 02:28 PM
cschow's Avatar
2006 Corvette Coupe
Sounds good, I may be heading to the drag strip myself tomorrow. I'll post my time slip and if they let me mount it, my g-tech competition data.
Old Mar 15, 2004 | 06:03 PM
cscollis's Avatar
C32 and 98 C5 Vert
Re: Simonlam understands my point
Originally posted by Vomit
Simon, you were at 318 with just the pulley. I am at 325 with another big chunk of $$$ spent besides the pulley. That's my point. It's as if I basically got the full thirty horses out of the pulley and a few out of switching to 93 octane, and that the $ spent on the ECU and the SL55 intake did not accomplish much. I have put more than 300 miles on the car since having the work done. When would one expect the sleeping mares to suddenly awaken? FYI I have not driven the car gently since the mods.
I realize that I am whining incessantly, but hopefully you all can understand my point. If I would have been happy with "30-something" additional HP, I would have just done the pulley.
It is too bad you did not goto the track before you modded. Trap speed is more accruate than a dyno. My vette only dynos 371 rwhp and 400 rwtq but runs 11.5-7 at 119-121.
I will goto the 1/4 mile track soon and test the old C32, Should do a low 13 based on my 1/8 mile. I am guessing 104-105 trap and for every 10 rwhp you pick up 1 mph. Also you can pick up mph by lightning the C32. Every 100lbs is good for 1.25 mph and .1 in the 1/4.
Just a thought.
Old Mar 15, 2004 | 08:07 PM
Vomit's Avatar
2002 C32 Black/Charcoal
C32 mods
Hey CSCollis:
I've been working on slimming the pig down (the car, too). I started out with a head start by not having the moonroof (someone's estimate was a 60-70 lb. saving there). Also, I installed the Optima battery (another 30 lbs). The Evosport pulley mods knocked off 13 lbs. My car has no options other than the CD changer and premium sound, which probably saves another few lbs. Next on the hit list are wheels. Being the stubborn **** that I am, I am determined to fit those 15 lb. SSR Comps on my C32. It looks like I will have to use a spacer in front, but that they should fit. I figure that those wheels, combined with swapping my Rossos out for Pilot Sport 2s or Toyos, should knock another 60 lbs. off the beast. I can't stomach swapping seats or anything of that nature, so that will probably be the end of the vomitmobile's diet (unless someone comes along with a great deal on a carbon fiber hood and trunk lid). I might be down to low 3400s or even high 3300s after the wheels/tires?
I think the low dyno had alot to do with the fact that the rocket surgeon who performed it did not have any cooling fans on the motor during the process. My guess is that the computer sensed the engine heating and retarded the timing, which would explain why my torque readings were higher than my HP. Also, I just installed some K&Ns and noted that my stock air filter was dark brown-very dirty. Maybe my imagination, but car seems to run a little stronger. I will try to re-dyno it this week, if there is time.
Anyways, you will eventually see Vomit post a sub 13 second 1/4 mile time. Like the dope-smoking suit guy says, "I guarantee it."
Old Mar 16, 2004 | 10:12 AM
cscollis's Avatar
C32 and 98 C5 Vert
Re: C32 mods
Hey CSCollis:
The easiest way to get a sub-13 sec pass is 60'. Put some bfg drag radials on the back and with the 108 trap that should be a mid 12. The BFG's hook like crazy. A good burnout and launch at as high rpm as you can before tire spin and floor it. You will be pulling 1.7 to 1.8 consistantly.
As for weight reduction, each pound off the wheels is equal to 4 pounds off the car.
Good luck on your quest. I am shooting for a high 10 in the vette N/A. Once I get the vette into the 10's, I will get the C32 into the 11's a 75 shot of nitrous should put it in the low 12's.
Have fun and if I can think of anything else to reduce the weight I will post it.
