Post Evosport Stage I dyno
Old Feb 25, 2004 | 09:38 PM
Vomit's Avatar
2002 C32 Black/Charcoal
Dyno'd my car post Stage 1 (Pulley + ECU/93 + SL55 Splitter) yesterday on 93 octane. 325 HP and 329 TQ. Not quite what I expected. I had done a pre-mod dyno three weeks ago which came out at 288 HP and 294 TQ (on 91 octane). The tests were done on the exact same dyno machine, by the same employee (of The Dyno Shop in Santee).
I notice that the air/fuel mixture drops from 12.0 at 5700 to 11.8 at 5800; 11.7 at 5900 and 11.5 at 6000. Any ideas?
I will post the printouts if anyone will tell me how.
Old Feb 25, 2004 | 10:11 PM
GS AMG's Avatar
Exactly! what I just posted why the MPG can get better. Leaner fuel mixture gets better MPG , AND more power. However "rich is your friend". Boosted motors should run a little richer IMO due to the maifold pressure and dynamic pressures of the engine. High 11 is fine IMO.
You still had close to 40 RWHP added why were you bumbed?
Old Feb 25, 2004 | 10:16 PM
simonlam168's Avatar
c63
Good number!
You dynoed your car in 3rd or 4th Gear?
Some thinks the 3rd gear is appropiate for testing. Other think 4th gear. Does anyone know which is correct?
Old Feb 25, 2004 | 10:48 PM
m444's Avatar
Audi C7.5 S6
A/F ratio sounds right for a street car.
If you have lots of money and can afford to replace the motor, then one could tune it leaner to 12.5, but I would NOT do this.
Fuel makes the mixture cooler and less likely to detonate.
Enjoy your power. By the way, the fuel grade and temp can make a big difference.
Don
Old Feb 25, 2004 | 11:07 PM
amgme's Avatar
07 SL550; C32 (sold)
I got 329hp and 321tq w/ the same setup but with heavy 19" wheels on CA91. my a/f ratio at 6000rpm is about 11.8 and 5800 at 11.9.
Old Feb 25, 2004 | 11:29 PM
Vomit's Avatar
Lazy pig of a C32
Based on Evo's estimates, I was expecting more like 340 hp out of the sow. Anyone have any ideas why I am producing less than the estimated 50 rwhp gain and why I am producing more TQ than HP (when the stock ratings have HP substantially in excess of TQ)? Give me your knowledge or I will find you and pour STP in your gas tank.
Old Feb 25, 2004 | 11:48 PM
Bux's Avatar
Bux
G
go dyno again after a few a hundred miles or so and see what happens ..maybe it was the temp in the shop? my dyno was on the low end of the scale compared to some others here but i ran a 12.9 (no pulley upgrades etc) in the quarter which is keeping me happy for now to stay away from mods
Old Feb 26, 2004 | 12:42 AM
Vomit's Avatar
The 185 mph 1/4 mile (Evil K. attempts the Grand Canyon)
You did a 12.9 stock quarter? Were you on a 6% downhill grade?
Old Feb 26, 2004 | 02:13 AM
SiLvaC32's Avatar
C32
my stage I dyno came out to be 340rwhp.
Old Feb 26, 2004 | 02:31 AM
ronnie0738's Avatar
2003 Nissan 350Z
I got mine dyno'd at 340ish also, but we need some better gas...cali need 93 at the pump, not this 91 crap.
Old Feb 26, 2004 | 02:54 AM
Vomit's Avatar
Thanks Silva and Ronnie for pointing out the painfully obvious: You spent the same $ and got more HP. Gloating BassTurds! (Now figure out why my hog is running slow!)
Old Feb 26, 2004 | 03:35 AM
SiLvaC32's Avatar
C32
go get some nice exhaust that will free up more HP!
Old Feb 26, 2004 | 05:20 AM
CynCarvin32's Avatar
Mercedes Benz
well
breathe in breathe out vomit!
Your car is FINE. The AMG Kompressor motors are known for a large discrepency in power. Some make well more than the claimed 349 stock while others make 10% less than the claimed number. The law states the car has the right to be 10% down on power and not be defective.
Your car is about spot on for power figures and remember Cali gas is = to donkey ****!
Some 5.5L Kompressor motors make 540hp stock while others make 469 hp. My fingers are crossed for my next car!
Run the numbers....340 is a great figure!
Old Feb 26, 2004 | 09:30 AM
Vadim @ evosport's Avatar
C32 AMG
Vomit: When K&N filters come in, bring the car back we will dyno your car again.
My guess it just needs some more miles.
Also the size and capacity of the dyno cooling fans is very important. If there is not enough cooling, DME will pull timing out at the top.
If you a chance e-mail or fax me your dyno run. Thanks.
Old Feb 26, 2004 | 09:48 AM
Bux's Avatar
Bux
G
Re: The 185 mph 1/4 mile (Evil K. attempts the Grand Canyon)
yes stock with just drag radials and on a official track not some g-tech time
Old Feb 26, 2004 | 11:34 AM
Vomit's Avatar
Post-EvoI Dyno
Thanks for the info people. The issue is not so much the absolute HP figure (325) as it is the less-than-expected Stage I gains (37 HP). Had my car been generating 275 HP before the mods, a post-mod reading of 325 would have been fine. Since I was already pulling 288 HP before the mods (on 91 gas), 325 HP (on 93 gas) does not thrill me. By all accounts, everyone is getting at the very least 50 HP from the same mods. Evosport seems like a well-run business with smart people, and I am sure that they (and all of you!) will help me figure out where the other 13 or so ponies went.
Old Feb 26, 2004 | 11:43 AM
Vomit's Avatar
HP
Thanks Vadim for agreeing to look at the dynos. I have faxed them to you. If anyone else wants a copy of the two runs, email me a fax number and I will send them to you.
A few comments about my pre and post-Evo mods runs: The barometric pressure was higher for the post-mods run (30.11 vs. 29.85 for the pre-mods run), the vapor pressure was higher for the post-mods run (.36 vs. .27 for the pre-mods run), the intake air temperature was higher for the post-mods run (71.3 F vs. 60.7 F for the pre-mods run), and the gear ratio was lower for the post-mods run (43.09 RPM/MPH vs. 61.19 RPM/MPH for the pre-mods run). As for the gear ratio issue, I had instructed the shop before both runs to do it in 3rd gear, as this is what I had read on the forum. Was one run done in 3rd and the other in 4th? Would any or all of these factors explain the relatively low HP gains from the pre to the post-mods dyno? I know that the 10 degree intake temperature difference would affect HP somewhat, but how much?
Old Feb 26, 2004 | 02:57 PM
SiLvaC32's Avatar
C32
it might be your driving style too.... give your car a week and drive HARD! let ur ecu adapt to the new mods... and dyno again, you shall see a difference.
Jerry
Old Feb 26, 2004 | 07:42 PM
c63
Vomit, I think 325 HP is a bit low. My car got 318.6 HP only from the pulleys.
Old Feb 26, 2004 | 08:29 PM
Vomit's Avatar
Simonlam understands my point
Simon, you were at 318 with just the pulley. I am at 325 with another big chunk of $$$ spent besides the pulley. That's my point. It's as if I basically got the full thirty horses out of the pulley and a few out of switching to 93 octane, and that the $ spent on the ECU and the SL55 intake did not accomplish much. I have put more than 300 miles on the car since having the work done. When would one expect the sleeping mares to suddenly awaken? FYI I have not driven the car gently since the mods.
I realize that I am whining incessantly, but hopefully you all can understand my point. If I would have been happy with "30-something" additional HP, I would have just done the pulley.
Old Feb 26, 2004 | 08:44 PM
Vomit's Avatar
Thanks Vadim!
Thanks Vadim (Evosport) for getting back to me on my dyno results. I continue to believe that Evosport is an excellent shop producing and installing excellent products at good prices. Your attention to customer concerns is admirable.
It sounds like my dyno shop down here maybe was a little "clueless." In particular, I do not remember seeing any cooling fans placed in front of my vehicle at the time the test was being run. If the timing was retarded by the computer as a result of engine heating, this would certainly explain the low HP figure (and would also explain why my "seat of the pants" evaluation of the modded car is alot more than 37 HP). Also, it looks like they used "standard" HP figures instead of SAE and did the post-mods dyno in 4th (rather than the requested 3rd). I will take the car back for re-dyno in the next few days & will post. I never realized dyno testing was such a touchy issue. Hopefully, this info will help others to avoid my mistakes/problems!
Old Feb 26, 2004 | 09:00 PM
c63
I got 367 HP in 4th gear.
(Pulleys + Powerchips + IC + SL55 full intake + Dual Exhaust <no mufflers> + 98 Octane + Gold Mobil One 0W50)
Weather: 20 c
Miles: 18750
I sent my own computer to Powerchips directly.
Old Feb 27, 2004 | 11:59 AM
cscollis's Avatar
C32 and 98 C5 Vert
This dyno thing has gotten out of hand. If you really want to know how much HP you are making:
1. weigh your car
2. goto a drag strip
3. get a mph in the 1/4
based on the weight and mph you get a very good reading of actual hp.
The dyno is a tuning tool, not a measure of your cars performance.
BTW: I have a heads/cam C5 corevette that only dynos 371 but runs 120 in the 1/4.
Old Mar 11, 2004 | 01:55 PM
cschow's Avatar
2006 Corvette Coupe
Vomit, did you ever re-dyno your car and if so what were the results?
Old Mar 11, 2004 | 02:25 PM
Vomit's Avatar
Re-Dyno
Hey CS: Haven't done so yet. Shop where I had it done has agreed to give me a freebie. Will probably do it next week (and make sure that they use some cooling fans this time). I'll post the good or bad news. Am also going to the dragstrip with Dink this weekend, we'll post our times next week.
