Dink and Vomit at Carlsbad Raceway
1. When the light turned green, the C32 was slow to get traction. Granted, most of the other cars had slicks on their drive wheels and we did not. However, even the cars that were running street tires seemed to jump alot better on the takeoff (G35, SRT-4s, Mustangs, Camaros). This meant that even plebian cars would get the jump on the C32 at the green light. I got beat (3 car lengths) by a freeging 1989 Honda Civic, for god sakes (granted, it was built, stripped, and running NOS, but it was still a 15-year-old Honda Civic!) Is there something retarded about the C32 differential? It just does not seem to get the power to the ground.
2. The C32 and/or Carlsbad Speedway seem to have particularly bad traction. No matter how gently we tried our C32 takeoff, it was as if you were on ice. We each did about 6 runs. The best 60ft time we could get was 2.5 secs. The pattern was: P.O.S. car jumps the C32 by about 4 lengths at the start. C32 (depending on the HP of the other car) starts playing catch-up at about 50 MPH, and wins or loses based on the 50-100 MPH race. Why can't the C32 compete in the 0-50? (please don't point out the obvious "sheety driver" factor!)
The best quarter was with my (evosported) car: 13.8 seconds. My Stage I car ran consistent 108 MPH trap speeds. We obviously had our hopes high reading about low 13 second quarters on the C32 forum.
Anyways: Some kills: Stock 2004 S2000 (some 15 car lengths, by Vomit); 2003 Rustang GT (Same, by Vomit); Nitrous Jetta (some 10 carlengths, by Dink); Supercharged Pontiac GTP "something" (10 carlengths, by Dink); "Big Exhaust, Heavily Modded (but no NOS) Acura Integra (5 carlengths, by Vomit).
To quote the words of our fine governor: "We'll be back." Probably return in a couple of weeks. Anyone interested, contact Dink or Vomit.
Until then, tell us how to get the dam'd things hooked up off the line!
With Evo Stage I upgrade (pulley+ecu), you'll need some drag radials to hook up better.
I had harder time hooking up at Carlsbad compared to California Speedway (Fontana) on street tires.
The best time i got at Carlsbad was 13.4 (Street Tires).
http://www.pbase.com/yogo/carlsbad_raceway_3292003
At Fontana, i got 13.3 (Street Tires).
http://www.pbase.com/yogo/california_speedway3
After putting on some Nitto drags, I got the time down to 12.9
http://www.pbase.com/yogo/carlsbad_raceway_9202003
peter
I love my C32 but my C5 with a 3800 stall with a 2.5 multiplier launches my vette to 1.60 60's. The only way a C32 could pull that off is with a bigger stall converter.
I have run the C32 at the 1/8th mile track.
60=1.96
1/8 = 8.66
mph = 83.49
Best so far but I am pretty consistant.
Every .1 off your 60' will result in -.178 in your 1/4 mile time.
To bad I am not in CA, I would love to run you guys in my C32.
Seriously, we kind of went about the whole process in a pretty casual manner. My car: Stock 17" Rossos with stock tire pressure; no "Rosso smoking" before staging. Everything about my approach to the whole process sucked: reaction time; 60 foot times; 1/4 mile times. I always thought that the 1/4 was "idiot proof," but then I tried it and found that it was not. About the only thing that I was pleased with were my trap speeds at the end of the 1/4 (108 plus on all 6 runs), especially considering that I spent the first 100 feet of the strip looking for traction. I think that with some slicks I could easily break 110 mph in the quarter.
Dink's car has 19" Neros on it (265, I think), and he had just as much trouble hooking up. I really think that 60% of the problem was a slick track, 30% of the problem was seated behind the wheel, and 10% of the problem was mechanical.
Cold tires=no traction, cold track=no traction, wet track=no traction!!!! I suggest that next time you go to the track early and get in some runs before the slick cars get water everywhere. But on second thought, if you are not going to heat up your Rossos, don't even bother to go! What 10% mechanical problem are you referring to? I have personally seen a C32 on OE tires and wheels do 1.86 second 60' times (my401) but he smoked the tires well before staging.
Get some BFG Drag radials. They are more than enough for the C32. They hook almost as good as ET streets at the track with less side wall.
We had a great time farting around at the Raceway, even if our times sucked. We just made some decisions not to take certain steps, which steps probably would have improved our times at the expense of tread life on the rear tires. To say that we "shouldn't go" ignores the 'fun factor' and is kind of nonsensical.
The answer (for me, at least) is a pair of slicks. Then I can let it all out without raping my daily driver's tires.
Seriously, MPH at the end of the quarter will go down if my 60' time improves?? This seems to be a strange concept but, then again, we live in a strange world. I assume that there is a limit to this concept. . . For example, if I am only going 40 MPH a third of the way down the run because I had no traction, my speed at the end of the 1/4 is not going to be very high. True?
I really think that a large part of the problem is simply too much power for the tires. I can't floor it any more in first gear without smoking the rears. Does this mean, in the 1/4 mile, that I am supposed to only give my car 1/2 or 2/3 throttle until it shifts into 2nd? Even in 2nd, my tires light up about half the time under full throttle.
I hadn't read your post about the BFG drag radials when I did my last reply. Are these the ones that you can actually drive to the track? I thought I remembered reading something about those somewhere.
Anyways, I will definitely check into them.
Hey CSCollis:
Anyways, I definitely check into them.
I have a second set of rims and the BFGs for my vette. They get me 1.60 60's where street tires I a lucky to break 2.0. That will cure your spinning problem. I have over 400 rwtq at 3800 rpms and they stick like glue.
Check at discount tire. Tires.com they have the best prices.
Vomit, I am in OC, Im down to meet up with you at Carlsbad as soon as I get my car back.
), then you'd have been looking at a low, low 13 ET. But since you now had less time (say almost a second less for this example), you'd have had less time to build your speed. Therefore your trap speed would have decreased slightly, but running a faster ET. Sorry, I can't help you on specifics of launching a 32 - never even been in one *L*, but I've spent wayyyyyy too much time over the years at the local track *L* and the best general advice I can give you at this point is as others have pointed out - get some drag radials! They'll be the cheapest way to a lower ET you'll ever find. I went from 2.0-2.1 short times on Eagle F1 to 1.7's on Nitto DR's - used 'em as my every day tire too. That's the nice thing about DR's over pure slicks - they make for a good all round tire. Just use common sense in the wet! Just air them down for track use and SMOKE the ever livin' **** out of 'em before pulling to the line. Nitto's LOVE to be heated GOOD for best results.
smoking regular street tires may lead to the rubber balling up on the tread...not exactly giving u traction... it's usually better not to smoke too much....
3000 rpm stall speed for the torque converter is pretty tall...not gonna be very streetable....
I would love a 2200 stall in the C32. I like the looser feel. Much smoother excellerating and hits harder when you launch.
I will check with evosport about a stall converter.
With a pulley setup the car will vaporize the rear tires by just pushing on the gas pedal from idle. Can't imagine a higher stall speed will make any difference on street tires.
If you want it to hit harder at launch then just add a Pulley set-up for more boost, rather than going inside the tranny for a torque converter. Besides the C32 TC is electronically locked, if you change it you will need new software.
It is incredible, when the car downshifts it throws you back in your seat hard instead of building torque and hp. With a messly 370 rwhp in my vette, it runs at the track a 11.5 at 120.
As for the converter locking up, all non-drag strip converters lockup for fuel economy. Hell I will buy one from Mercedes and send it to Mike at Yank for reverse engineering if I have to.
The converter is a better mod for performance than a pulley at the track. The pulley will get you more 2-3 mph while a converter will reduce your et by as much as .5. I would rather go 12.9 at 105 than 13.4 at 108.
I know theres not a big market for C32 or even MB converters, but all fast autos have a higher stall than the C32.
