Tire wear
Old Oct 25, 2016 | 09:56 PM
Fopi C55's Avatar
C55 AMG
Question Tire wear
Hello peeps it's been awhile,I've been having some premature issues,hahaha not that kind but some rear tire probs. I'm getting more wear on the inside of my tires than normal,I've looked over all suspension components and I don't see anything wrong or out of the ordinary. I did a little research and found some adjustable bushings that can and will replace the stock bushings. Any help or ideas with this matter would be appreciated.
Out Fopi C55
Old Oct 26, 2016 | 02:19 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Hello there. I too was alarmed at how badly the tire wears on the inner section. It is normal on AMG models and cannot be adjusted. However with aftermarket options today, you can get aftermarket rear camber adjusters installed which will then remove this issue you are experiencing. Have a look on google for rear camber adjusters for your model car and have them installed at someone reputable. Replacing bushings aint gona cut this one.
If you were experiencing the same problem with the front like I am, then you can replace bushings. But if that doesn't cure it then you would require the fluted bolts and then adjust them from there but this can only be done on the front as far as what I recall reading on this forum.
Good luck
Old Oct 26, 2016 | 09:56 AM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Just push harder through the corners so you wear the outside as well. /only partially serious
Old Oct 26, 2016 | 12:51 PM
Fopi C55's Avatar
C55 AMG
Good luck
yeah that's kinda what I figured after doing a little more research thanks for your input Khan having a second opinion helps!
Old Oct 26, 2016 | 12:53 PM
Fopi C55's Avatar
C55 AMG
Hahahah I like your style but the wallet seems to get a bit lighter when I do!
Old Oct 27, 2016 | 05:47 AM
Khan 55's Avatar
2004 CLK55 AMG W209
No sweat Fopi
Yeah them tires aint cheap. Need to replace fronts on mine due to worn control arm bushes which I need to find the time to get down to.
Old Oct 27, 2016 | 08:25 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
I just always figured in about 1k a year in tires and part of the maintenance cost.
Old Nov 4, 2016 | 10:17 AM
thtguy's Avatar
2017 GLS 550
I think K-MAC has C bushings as well. they will give you full adjustment for camber and caster. front and rear.
