Question on rear caliper upgrade.
Old Feb 3, 2017 | 01:23 PM
MrVu's Avatar
2005 Granite Gray C55
So my friend is offering me a pair of rare Alcon Brabus rear calipers for $300. Definitely a great price and hard to refuse the offer.
Question on rear caliper upgrade.-16442979_10211388472364927_1043325151_o_zpsieutvapr.jpg
I know these will fit on our 300x22 rear rotors, but my biggest concern is the balance in the brake system.
Doing this will lead me to have 4 pot fronts and rears, and I'm hoping that the fronts are bigger still and will contribute to at least 70%+ of the stopping force.
What are your thoughts?
Thanks guys!
Old Feb 3, 2017 | 05:44 PM
KJI3jflarryfe93's Avatar
you can't have 4 pots on all 4 corners.
if you do a hard brake you will find out why it's dangerous with same size piston calipers in front and rear.
put 6 piston calipers in front go with 4 in the rear
Old Feb 3, 2017 | 06:59 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
What matters is the surface area of the pistons.
Old Feb 4, 2017 | 01:59 PM
dsp_tdi's Avatar
2005 C55
I have 4 piston rear calipers with slk55 rotor (13'') and not problem with stock front calipers. Just better brake balance
Old Feb 5, 2017 | 07:19 AM
depends on how hard you brake in a traffic situation.
if a dangerous situation occurs you need to hit brakes hard car might spin 360 because of the even brake force.
there's a reason why manufacturers use less pistons in the rear than in front
4/2 - 6/4 etc etc
Old Feb 5, 2017 | 10:26 AM
Viper98912's Avatar
Has nothing to do with the number of pistons.
Old Feb 5, 2017 | 09:39 PM
johnng117's Avatar
2002 C32 AMG
I agree...
More pistons doesnt mean more braking force, its more evenly distributed... The size of the pistons are the main factor..
Think about it.. If you have a mini 6 pot at front and large 4 pot at rear the 4 pot may have a larger force.
Old Feb 6, 2017 | 01:24 PM
dsp_tdi's Avatar
2005 C55
2, 4 or 6 pistons are just for a better distribution on the pads, if you check the piston surface between 4 and 6 pistons (example front), they are very close. The biggest differences are the size of the brake pads and the size of the rotor. The power braking between 2 pistons vs 4 pistons are the same. If you want a car to make trail braking, you need more rear brake then stock. Stock brake ratio are conservative.
Old Feb 7, 2017 | 03:22 PM
MrVu's Avatar
Thanks for the information guys! I'm having my friend take more pictures of the calipers for me sometime today.
Just for clarifications, I am able to run it on my stock setup if I measure the diameters of the pistons? If the pistons on the alcon are bigger than the fronts, I should just avoid it?
Thanks guys!
Old Feb 7, 2017 | 06:22 PM
Viper98912's Avatar
You need to calculate the surface area of the stock pistons (which I think are 42mm) and the new one. If you have a significant change in rotor size, that as well.
I'll be honest - you need to do a lot more research about brakes and upgrades and calculations. This isn't something that you do easily, nor just make a bracket and pop them on. You realize that there's many ways to injure (kill) yourself, and more importantly, other people, by doing this if you don't know what you're doing?
