Is this normal?
Old Apr 2, 2017 | 02:03 AM
badbenzz's Avatar
AMG GTS, Ford Raptor and Tesla Model 3 dual motor
Is this normal?
I have a C55 and it turns out to use the keyfob, I have to be at the drivers door at all times in order to lock and unlock the door. Is this normal for the C55. All my other MB cars allow me to use the keyfob anywhere near the car and further.
Old Apr 2, 2017 | 03:27 AM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Sounds like the keyfob battery is really low and about to die as I believe the transponder is in the driver's door. Before I changed mine, I had to have the key almost to the driver's door handle to get it to unlock.
Old Apr 2, 2017 | 07:56 AM
Morphh's Avatar
C32 amg
Needs new battery
Old Apr 2, 2017 | 11:50 AM
badbenzz's Avatar
The batteries were replaced
Old Apr 2, 2017 | 06:05 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
In a parking lot, I can be pretty far away from the car and if there's no interference, it can reach pretty far
Old Apr 3, 2017 | 12:46 AM
badbenzz's Avatar
My rf receiver must be bad
Old Apr 3, 2017 | 01:10 AM
Rocman8's Avatar
E55
You need the antenna that's stuck to to upper edge of the rear glass under the headliner. Your am radio reception will probably be out as well.
Old Apr 3, 2017 | 03:39 AM
Bigpapistu's Avatar
03 E55
I had a problem similar to this with my key fob. When I purchased my car the key would function properly but not unlock from really far away (unlike you where you have to get up close to the car to unlock/lock it). Then a year later my batteries died, so I replaced them. Same thing. Then my batteries would die every other week. I though I'd have to get a whole new key from the stealer. I ended up buying a used key fob on eBay and switched out the battery holder thingy (picture attached) and my key started working again plus I could lock/unlock from very far now. It was a miracle and problem solved I would try that option if you have the same key fob before purachasing a new key.
Old Apr 3, 2017 | 01:10 PM
Oshkoshbigjosh's Avatar
2005 S55 AMG Designo, (sold)2001 ML55 Designo, (sold)2004 C32 AMG, RIP 2005 Volvo s40 2.4i
Wait, you just bought a fob and replaced the battery holder? No motherboard or dealership involved?
Old Apr 3, 2017 | 01:19 PM
PJmak's Avatar
yea do tell
Old Apr 3, 2017 | 03:47 PM
Bigpapistu's Avatar
03 E55
Yes. The key fobs on eBay come in used condition that were programmed to vehicles at a time.
The battery holder has nothing to do with the mother board. You can pop it out in 2 seconds just search it up on YouTube
Old Apr 3, 2017 | 04:16 PM
PJmak's Avatar
Are they the same for all keys?
From what I know there are three types of keys for w202s for example.
I have like three bad keys between my two w202s
Old Apr 4, 2017 | 05:39 PM
badbenzz's Avatar
My car is at the stealership and we will see if they can figure it out but most likely the antenna.
Old Apr 5, 2017 | 01:41 PM
badbenzz's Avatar
OK the dealer claims its the window tint.....despite the door handle sensor not working
Old Apr 5, 2017 | 02:15 PM
Rocman8's Avatar
E55
Your first post you said the door handle sensor is working.
Old Apr 5, 2017 | 03:21 PM
badbenzz's Avatar
The door handle is intermittent
Old Apr 5, 2017 | 04:19 PM
Window tint? Is it leaded tint and covering the entire car, paint and all?
Old Apr 5, 2017 | 04:44 PM
badbenzz's Avatar
Just window tint not a wrap. Its the rear window they claim is the issue. I'm going to pull it off and see if that fixes the issue but I am very very doubtful as it is most likely the antenna since it would lock or unlock while inside the car either.
Old Apr 7, 2017 | 04:18 PM
MacVidMB-V8's Avatar
W209, W124
This is why I'll never get my windows tinted.
When they trim the edges they use an exacto to get a nice clean cut of the plastic film.
Also cuts the wires at edge of the window nicely too.
Old Apr 7, 2017 | 04:34 PM
badbenzz's Avatar
Actually many tinters use a computer to cut the tint now without razor blades. Decided in lieu of searching for the problem I am just going to install a alarm system with door lock/unlock feature problem solved for much cheaper than hunting down the problem.
Old Apr 15, 2017 | 09:28 PM
Jon@MBPartsFactory.com's Avatar
Former Vendor of MBWorld
Mercedes
Why don't you just try unlocking it from inside the car? That should help determine if it's the tint. You should be able to unlock it by pointing it at the IR receiver on the door handle regardless of the tint. Unless the key or IR receiver is failing as well. You can actually see the IR if you turn on your camera on your cell phone and hold the unlock button and view it from the phone pointing the IR lens at the camera lens.
Old Apr 16, 2017 | 12:30 AM
badbenzz's Avatar
The remote does not work on the inside of the car and the ir on the door is intermittent. Thus both sensors are shot. Hence an alarm with door locks is better than getting both sensors replaced or at least cheaper with much much greater range.
