06 C55 AMG Performance Cooling fan
Old Apr 20, 2017 | 06:28 PM
AtlasMG's Avatar
2006 Mercedes-benz C55 AMG
Hi everyone im new to owning a c55 its my first car and the forums. I have a 2006 Mercedes C55 AMG and my cooling fan broke I took it out and gave it 12V and still nothing so im in the market for a new one. The problem is that OEM one is 600 and I was thinking is there a Performance one that can fit the c55 like mishimoto or ISR?
Old Apr 20, 2017 | 06:42 PM
PJmak's Avatar
Can you post the part number?
Old Apr 20, 2017 | 09:13 PM
AtlasMG's Avatar
I can post part number tomorrow I have it at work so cant right now. but its the hole radiator cooling fans assembly
Old Apr 21, 2017 | 12:26 AM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
aftermarket versions are less than $200.
Old Apr 21, 2017 | 10:35 AM
PJmak's Avatar
Im asking coz I have a spare one from a w202 c43 amg. Wondering if they could be same
Old Apr 21, 2017 | 12:06 PM
cm60k's Avatar
As i remember; the power range of C55 fan is (850W),,
there are many power brands in market, but have to use the same or little bit more power than OEM fan..
-;ZAYED;-
Old Apr 22, 2017 | 06:49 PM
AtlasMG's Avatar
Im really sorry i forgot to get it we had a really hard day at work.
Old Apr 22, 2017 | 06:51 PM
AtlasMG's Avatar
I know the OEM fan has 4 wires 2 big ones RED and BLACK and 2 little ones what are the 2 little ones? and if i go aftermarket can i just put it on and connect the power wires and ill all work or will I have to do something with those 2 little wires?
Old Apr 22, 2017 | 06:55 PM
AtlasMG's Avatar
Is it possible for someone to link me to an aftermarket performance fan or a cheaper OEM one?
Old Apr 22, 2017 | 11:31 PM
cm60k's Avatar
If i'm not wrong; your fan controlled by ECU, for variant differ speed range, through temp. sensor signal,,
i think if you go with aftermarket fan, you have to put relays to control the differ speed, when the temp rise up..
-;ZAYED;-
Old Apr 23, 2017 | 10:23 PM
AtlasMG's Avatar
Hey do you know what the difference is between the 10 blade cooling fans and the 7 because mine has 10 blades and those are way more then the 7 blade ones like 200$ so what is the difference???
Old Apr 23, 2017 | 11:21 PM
cm60k's Avatar
As i know; "W203/W209/R171":-
*7 blades= (600W)
*10 blades= (850W)
-;ZAYED;-
