C55 leaking rear main seal
Old Jun 5, 2017 | 11:33 AM
PJmak's Avatar
Was doing my oil change and noticed a good amount of oil on the trans plastic cover and some oil up where the trans connects to the back of the motor.
I wiped the cover down and drove home(20ish miles) where I took it off again to check. There were already three-four drops on the cover again so it seems that the leak might be pretty bad.
My concern is that the person I trust to work on my cars wont be available for about a month or two. Can I drive like this? Should I get a trans dip stick and keep checking the fluid level in the mean time and add if needed until I can get it fixed?
Old Jun 5, 2017 | 03:29 PM
PJmak's Avatar
Originally Posted by Plutoe
Sounds like a good idea, assuming the leak is from the transmission. However if it's oil, it may not be
Dont know much about this.
Rear main seal seals the back of the motor right so it would be engine oil not trans fluid? I might have gotten things mixed up
Old Jun 5, 2017 | 05:54 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Oil is gold/black fluid
Trans is red fluid
Old Jun 7, 2017 | 02:35 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Did you trace the leak with a light if possible to see its main stream? I checked mine one day thinking I too had the problem. Found out it was my dipstick tube o-ring seal. It doesn't seem to hard to replace but I will have to find time doing it.
Old Jun 7, 2017 | 09:36 PM
RenC55AMG's Avatar
2005 C55 AMG
Just had mine replaced; have to remove the transmission to replace it. Cost me about $1,000.
Old Jun 13, 2017 | 04:45 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Almost every m113 has a rear main seal leak. Keep an eye on your oil level and you will be fine. Eventually it will just give way and dump oil faster than you can put it in but it will take some time to get to that point.
Old Jun 16, 2017 | 11:01 AM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
Rear main seal, extremely common.
Trans is red fluid
Trans fluid usually won't be red unless it's extremely fresh, it will usually be anywhere from gold to black depending on age. This is normal and MB states to not judge condition by the color.
Old Jun 19, 2017 | 05:59 AM
tw2's Avatar
tw2
Insist they replace the plate the rear main seal fits into if they weren't already going to. This is half the problem when they leak.
Old Jun 19, 2017 | 05:24 PM
benzslo's Avatar
I have never replaced that plate and have never had an issue, done many. You do have to remove it and reseal it but I've never replaced it and haven't had any come back.
Old Jun 19, 2017 | 06:29 PM
PJmak's Avatar
Took the trans plastic cover off a week ago or so and I just cant get the car o drip so I could see what exactly its leaking :/
Im gonna have to lift it and investigate but we are already into 100+ degree weather over here.
Old Jun 19, 2017 | 08:47 PM
tw2's Avatar
tw2
Careful resealing is fine. The part is fairly cheap, not sure why you would risk it.
Old Aug 13, 2017 | 03:56 AM
duke749's Avatar
C55 AMG
check your cam cover seals
my cam cover seals leaking so bad it made me think it was crank seal
Old Aug 17, 2017 | 04:18 PM
skullbox15's Avatar
2014 C63
Had the same problem on my C32, although mine never leaked that bad. A friend of mine had his E55 leaking daily. It won't hurt the car as long as you keep replacing the fluid.
Old Aug 24, 2017 | 04:00 PM
93Corrado's Avatar
'05 C230 SS, '94 E420 (RIP), '05 C55
Trans is red fluid
and you can tell by the smelling them too
