///AMGSC C55 Build
Old 06-02-2020, 03:49 PM
  #51
jake gab's Avatar
c32 amg
I saw your C32 thread on your build and am having issues with mine whats Jeff’s shop
Originally Posted by ///AMGSC
I'm back in the AMG game. I missed the C32 too much after trading in for the GLK so I just had to find another one. I lucked up and found a 05 C55 with 85k miles and I gladly took it off the seller's hands haha Finally I can do the build I've always wanted to do...c55 with clk63 front end.
Old 06-02-2020, 08:16 PM
  #52
kaixdiego's Avatar
2005 6spd Manual C55 AMG; 2000 ML55 AMG; 1994 E420; 2008 ML63 AMG
Sway bar and brake kit GONE!! Only things left are the grilles.
can you please share what thickness size the black series sway bars are? This is pretty much unknown info to the internet and would be very useful for future reference. PLEASE lol
Old 06-03-2020, 01:55 AM
  #53
Slava30490's Avatar
W166 ML350 BLUETEC, W203 C55
24 mm front, 22 mm back. https://www.drive2.ru/l/549997707519853524/ enjoy
The following 2 users liked this post by Slava30490:
kaixdiego (06-03-2020), Spooky55 (06-07-2021)
Old 06-03-2020, 02:58 AM
  #54
kaixdiego's Avatar
THANK YOU! Had searched for that info everywhere... interesting to know it is thicker than the H&R rear bar.
does anyone know the stiffness ratings between those two bars 22mm vs 19mm?
Old 06-10-2020, 05:16 PM
  #55
3carswithstars's Avatar
1970 280s, 1992 300te, 2005 c55 AMG
If anyone local wants the sway bar kit, brake kit and grills come pick them up. If not local, pay the shipping. Need the garage cleared.
How much for the carbon grill?
Old 06-11-2020, 01:15 PM
  #56
brauhaus313's Avatar
asdas
I wonder if 22mm is the actual measured spec or just based on the pictures from that russian website. The pics indicate that the BS swaybar is 22mm but also the same diameter as the stock rear C55 swaybar, which is 16mm. Doesn't quite match up. The rear bar is also not a direct fit unfortunately.
Old 06-11-2020, 04:02 PM
  #57
kaixdiego's Avatar
I also found it curious that it appears the same size as the stock sway bar... I ended up going with the H&R rear a while back after I couldn't find an Eibach one ANYWHERE and couldn't find the specs for the BS sway bars ANYWHERE until this thread.
Front and rear H&R on stiffest settings work very well in combo with upper bracing in rear from Ultra Racing.
Quick Reply: ///AMGSC C55 Build
