C32 entire car shut down
Old May 12, 2020 | 06:56 AM
JC3388's Avatar
C32 AMG, CLA45
Hi everyone. I need your expertise here, any help is much appreciated!!! This is the fourth times it happened in the past 2 years (twice within the last 2 months) and never happened before that.
2002 C32 with just under 100,000 miles/160,000 kms.
Incident: Stop at traffic light (totally flat surface with 90% full of fuel), on sport shift mode 1st gear, when light turned green, as soon as I leg go the brake before I step on the accelerator, the entire car shut down. Not only the engine, lights, radio, all shut down instantly, put back to park and start the key, it would fire straight up and continue my journey. This happen 2 times in the last 2 months. Engine should have been warmed up in both occasions Driven over 10 miles before the incident). Other than the engine light which is to do with secondary pump, NO OTHER lights showing at all.
Recent fix: Have the engine gaskets replaced due to slight leak and also changed all Bosch spark plugs (6 months ago) . Replaced Secondary Air Pump 3 months ago (But could be a faulty unit since the engine light is on again and I used OBDII to check and came up pump failure). Also changed alternator 2 months ago as the unit was not charging and have a slight burn smell. Didn't drive much due to the pandemic (less than 400 miles). When started engine, some fuel/burn smell is definitely noticeable. Car was serviced 8 months ago with 0W40 Mobil 1.
Could somebody pointing me to the right path?
Many thanks!!!!!!!!!!!!!!!!!!!!!!
JC
Old May 12, 2020 | 11:23 AM
kaixdiego's Avatar
190E, C36, C55, CLK55, ML55
sounds like battery to me, I would start there. also, make sure you completely clicked in your spark plug boots to the tops of the plugs. Some brands of wires really need to be pushed on to actually click down, lack of doing this resulted in sporadic shut downs and weird behavior on my C55 before I realized.
It would be a good idea also to post what brand parts you got and where you got them.
Old May 12, 2020 | 03:54 PM
Oshkoshbigjosh's Avatar
2005 S55 AMG Designo, (sold)2001 ML55 Designo, (sold)2004 C32 AMG, RIP 2005 Volvo s40 2.4i
Could be the spark plugs but then it would just misfire unless you’re getting no spark from all cylinders and that would mean 6 bad coils/ 12 bad plugs which is highly unlikely and if it is the case then prepare to spend about 200 at least for a complete set.
I doubt your alternator is the problem unless your odometer screen is turning red and loudly beeping every 5-10 minutes from low battery voltage.
If you’ve replaced a lot on the car I would not look there yet. If you say you smell fuel then it could be a failing fuel pump or sender unit, or fuel filter. I doubt your injectors are causing a leak and there is a fuel hose in the top of your engine driver side that is near the air intake plenum that might be leaking or not fully torqued.
I had an issue about 7 months ago where my car would lose power and then shutoff. I did not smell fuel but it felt like a fuel problem. Fortunately I had a OBD reader and got a code for crankshaft position sensor. These are inexpensive, a pain in the *** to replace, and can easily cause your car to lose power while driving or at a stop (hence why it lost power while accelerating after releasing the brake)
I suggest you plug in a code reader and get some codes first. If no codes, get back to us with more info.
are you in SoCal?
Old May 12, 2020 | 10:05 PM
kaixdiego's Avatar
Not spark plugs, the actual wire boots that click to the top of them, if they aren’t clicked on is what I meant. Probably not the case, but it lead me down a rabbit hole before I figured that out. Also agree with the possibility of the crank shaft position sensor. As much info as you can to get the answer following.
Old May 15, 2020 | 04:40 AM
JC3388's Avatar
C32 AMG, CLA45
Hi kaixdiego - I initially thought battery could be the case as I have the alternator failed couple of months ago but since I changed to a brand new Velo alternator, I have been closely monitoring the voltage so I access the so called secret menu and voltage shows all the time. Battey is approx 5 years old and definitely not like a new one but maintain approx. 13.5 - 14.1v while driving. A but low when cranking approx 11v. I took to the mechanic to scan for codes, however other than the "secondary air injection system P0410", no other codes can be found. I asked the guy there and he said it is very unlikely the CPS is failed as I don't lose power while driving, and when the car is stop at the light, engine is still perfectly still running. The shut down only happens in the split second when I right foot let go the brake but before I step on the accelerator. On top of that, when is shut down, cigarette lighter, radio all shutdown together. Once I put the gear back to park, I can start the car straight away and the car won't suddenly shut down while driving (at least not yet).
Old May 15, 2020 | 04:49 AM
JC3388's Avatar
C32 AMG, CLA45
Hi Oshkoshbigjosh
I changed all spark plugs within the last 6 months while replacing the gaskets. I don't find the car ever misfire. I use
BOSCH Suppressed Spark Plug FR7KPP33U+
ELRING KLINGER gaskets, and
MAHLE FUEL fuel filter.
I have been constantly monitoring the alternator using the secret menu for voltage and is between 13.5-14.1v while driving as I paid nearly $2000 to fix (only 2 brand new unit in Australia) so the supplier want to jack up the price to $1200 and since the car is already in the mechanic and they have taken the old unit out, I don't really have an option unless I pay them for putting all the things together and pay again when I get the unit from Germany which I know is approx 700 AUD but will take at least 2 weeks to come.
Old May 15, 2020 | 10:23 AM
kaixdiego's Avatar
Your voltage is still a bit low so I would have battery tested to be sure but sounds like something else with what you’ve said. I don’t know they possibly of this or if it was an issue for c32 much but the brake light switch could be possible based off the pedal sequence before shutdown. I would go through all fuse and relays as well as their diagrams and see if anything could be the culprit, with no code that is possible. If there is only a code for sai, have you ever cleaned the egr piping out? Check hose in engine bay for vacuum leaks. That’s about all I can think of at the moment but keep this thread alive and keep updating so we can figure it out 👍
Old May 15, 2020 | 08:51 PM
YNVDIZW124's Avatar
lots of cars
It's the crankshaft position sensor
Old May 20, 2020 | 12:52 AM
JC3388's Avatar
C32 AMG, CLA45
However, my mechanic told me if the CPS is faulty, you cannot start the engine again until it cools down. However I can re-start immediately and I don't feel any abnormal engine vibration or loss of acceleration.
Old May 25, 2020 | 10:25 PM
RPB's Avatar
RPB
The original CPS on mine failed around 71k. It displayed almost no signs of premature failure. I assumed it was related to the fuel pump at first being that I parked forward facing on my inclined driveway. It cranked the following day and drove fine. I replicated the scenario and let it sit overnight in the same position. My car refused to crank for the next 2-3 days prior to replacing. I scanned before the CEL populated to confirm the CPS was the culprit. I recommend you try doing this and make sure to replace it with an original part if need be.
It kind of gets me when some people are so sure they know exactly what the problem is after reading a few sentences. Don’t just throw parts at it. This thread might offer-up some insight: https://mbworld.org/forums/c32-amg-c...need-help.html.
GL!
Old May 27, 2020 | 07:21 AM
cdk4219's Avatar
95 SL600
I had cps failure just like that. Car was idling at temperature and suddenly without warning stalled. This happened 2 times and both times the car starter right back up. The third time however after stalling the car wouldn’t start until it cooled. Cps is pretty inexpensive and would guess that to be the problem.
Old May 28, 2020 | 11:15 PM
RPB's Avatar
RPB
It should be throwing a code which made me question the CPS as being the culprit. The OP resides in the land down under, so nothing is inexpensive or readily available. In addition to it being a pain in the butt to remove and replace for no reason.
Old May 29, 2020 | 11:01 PM
alb3rtt's Avatar
2002 C32 AMG (SOLD), 2004 C55 AMG
I dont believe it is the CPS. As RPB said, the CPS would show codes and also as JC said, the CPS would result in difficulty starting when hot. Adding to this, a CPS failure would not result in the ENTIRE car shutting down, only the engine. I suspect a main power cable for the battery is damaged, resulting in a poor/intermittent connection and the car shutting down when this connection breaks. Perhaps the main ground, or the wires leading to the front sam, or even the front sam itself. Something along those lines is damaged would be my guess.
Old Jun 1, 2020 | 02:05 AM
kaixdiego's Avatar
Hopefully we get an update to know what has or hasn't worked. Interested to see what has or will be found, everything is an educated guess atp without further info.
Old Jun 5, 2020 | 07:22 PM
RPB's Avatar
RPB
After thoroughly looking over the OPs post, I do believe the issue is electrical related as previously stated. I’m leaning towards a bad ground or lose connection somewhere. The fact it happens when letting go of the brake which creates an instant jerk only adds to it. A faulty CPS or ICV should throw a CEL, but what I overlooked is the fact that all the lights shut off. I never heard of such a thing happening with these parts.
I would begin by checking the connections around the battery and alternator. I don’t think he has anything serious going on. Tracking it down can tend to be a bit of a stickler at times which is hopefully not the case!
Old Jun 11, 2020 | 08:04 AM
JC3388's Avatar
C32 AMG, CLA45
Thank you everyone who tried to guide me through what could be the real culprit with my situation. Scan didn't come up with any code and my mechanic couldn't pin point the issue either. I mentioned earlier that my battery isn't at its best state when crank sometimes got down to 9.7 then back to 14.1, so just changed a new battery. So far I haven't had another shut down since my post began. I don't want to endlessly pumping money to the mechanic so will see how's the new battery holds up and give it a month to see anymore shut down and give you guys an update. However, I will constantly come back to check any new suggestions.
Old Jun 11, 2020 | 01:02 PM
hey man thanks for getting back to us with your potential issue/fix. It’s important to follow up for other owners to see a possible solution when dealing with scary issues like this one. I know many people commented the crankshaft sensor (I did too) and it’s still a safe bet that it would be on it’s way out in the future if it hasn’t been changed in a long time. It’s very much a wear item on our cars so if your car shuts down again in the future rule out the battery and go after other things that could shut your off like the cps, alternator, fuel system, etc. because new batteries are highly unlikely to fail unless they’ve been sitting for a very long time.
these issues don’t always throw codes until theyre really malfunctioning and sometimes some you’ll need a more sophisticated tool to get more data on what’s going on with your car.
for example at the beginning of my cps issues my car shutoff maybe once in a month and it never gave me a code until it started happening more frequently. Just be on the safe side and be ready with having one on hand just in case. The job isn’t very difficult for m113 NA motors but it is quite a bit of work for our m112k engines. If you do it yourself you’ll save a ton of money and know that you did a great job which is something I recommend.
Old Jun 14, 2020 | 08:50 AM
JC3388's Avatar
C32 AMG, CLA45
Originally Posted by Oshkoshbigjosh
hey man thanks for getting back to us with your potential issue/fix. It’s important to follow up for other owners to see a possible solution when dealing with scary issues like this one. I know many people commented the crankshaft sensor (I did too) and it’s still a safe bet that it would be on it’s way out in the future if it hasn’t been changed in a long time. It’s very much a wear item on our cars so if you your car shuts down again in the future rule out the battery and go after other things that could shut your off like the cps, alternator, fuel system, etc. because new batteries are highly unlikely to fail unless they’ve been sitting for a very long time.
for example at the beginning of my cps issues my car shutoff maybe once in a month and it never gave me a code until it started happening more frequently. Just be on the safe side and be ready with having one on hand just in case. Fortunately the job isn’t very difficult for m113 NA motors but it is quite a bit of work for our m112k engines. If you do it yourself you’ll save a ton of money and know that you did a great job which is something I recommend you do yourself.
I also has the M112 k engine which I recall the CPS has been replaced approx 4 to 5 years ago when there car won't starts until the engine cool down. Do at this point I will continue to monitor any strange activities. Just found out my hand brake release lever is broken. Not the handle you pull, but the plate with 2 torx screws that hold the handle.​​​​ The positive side is the party aren't expensive and can DIY.​​​​​
