Modded Stock Exhaust Performance Problems!
Hello, i recently did a secondary cat deletes and resonator was removed; it seems like my car lost quite a bit of power or it doesnt run like a beast like it used to, it seems like my c230k is faster or accelerates faster; should i put my catalytic convertor back on, or should i get a magnaflow convertor, or a flowmaster on. Please let me know; what i should do- i want my car to be fast again :/
I would start with disconnecting the battery for 15 minutes then take it for a good drive on the freeway.
Maybe the ecu needs to reset it self to get used to a different kind of exhaust
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
Be patient, lots of good tech folks on here.... but it will certainly take longer with no codes for hints at what your issue is....
So after the exhaust changes you reset the ecu and it worked for a few days ?
thanks
