Rubbing & C32 -- What else is new?
Yesterday I installed the following:
18" HRE 547 (8.5 in front, 9.5 in rear)
Pirelli P7000 (I know, they suck -- but were free)
-225/40/-18 (front) & 255/35-18 (rear)
H&R Springs
After install, the rear springs were WAY too low and rubbed a whole lot with only 1 person in the car. The rear H&R's were taken off and the stock springs were put on, measured, and cut to be in between the stock drop and the H&R drop.
With 1 person in the car (me), I experience little rubbing on large inclines and bumps (which I can live with). However, with 2 people in the car (me & passenger) -- I rub on both rear tires about 1 1/2 inches down on each when making turns, bumps, inclines, etc. It's rubbing on the inner fender to the tires (the dust cover?).
I know just about everyone has chimed in at one time or another on this topic, but I want an exact answer on my situation.
Harris? AMG BRED? Anyone?
I appriciate the help in advance.
Sean
With the right offset you can get 265's with no rubbing.
Anyone else?
Then again they would always rub on big bumps since the tire will always travel the same distance up the wheel well.
Good Luck
I would suggest what zeppelin said, put the H&R springs back, up the spring pad size to something bigger so you won't sit as low. The H&R Springs are progressive springs and have a way higher spring rate then the stock springs. Next thing to do since your wheels will be off the car is to look at the at lining and see where the tire is rubbing.. take a dremmel and trim it down.. One of the main rubbing spots is where the bumper is attached to the body, there is a piece of metal that sticks out into the fender-well.. running your fingers along the backside of the fenderwell closer to the outside, you should be able to find what i am talking about. The bolt that you see can easily be relocated as well.
I still cant und why people would cut stock springs on a 60k car
*On another note, thanks AMG BRED &* Zepplin for your information. It is the offset that is the problem -- which I will have to get corrected by doing a couple of options.
*Harris -- you are the man! I want to thank you for all the ideas about how to fix my problem. I think I have a solution(hopefully) and I can get them not to rub anymore once I do the fix.
*Well, I didn't cut them because it was a cheap alternative, it's because I thought it would be a good median between the Stock and H&R drop. It's definelty not because I am too cheap and I'm looking to cut corners -- if that's what your trying to imply.
gotcha, i did say it because all i see on mb forums is talk about cutting springs and people thinking thats a viable option for lowering a car.
The rubbing is much worse than just by changing the spring pads.
but wouldn't the thicker spring pad bring the car a little higher off the ground? I thought he's problem was just simply too low because the rim and tire size should not be a problem.
don't forget your car's suspension is designed to move up and down with the contours of the road, in other words - wheel travel.. the suspension on the C32 is designed to camber when pushed up into the body.. to like an up and in movement.. if your offset is wrong regardless of how high or low your car sits, it's going to rub.
cool...understand! BUT shouldn't the HRE be made to order? unless he bought it off someone or just gave them the wrong info.
The wheels/tires actually look totally sweet & agressive with this offset (which is 27) but the rubbing is just ANNOYING!
Once the weather gets better I'll post some pics of my car.
