I'd like to swap my rear end for a more efficient one.
The guys in Van Nuys are a little sketchy if you ask me.
About the gearing, you are wrong idiot! On a car with a 3.46, the 3-4 shift is about 95mph. You are getting confused, the terminal speed of 4th gear (i.e. 1:1) is about 130mph. I think a 3.46 in a C32 would be too aggressive (first gear would be a pointless exercise in tire destruction), I would go with a 3.27 first w/an LSD.
2002 C32 Black/Charcoal
So I take it from what you are telling me that I cannot just get a $299.00 set of gears, jack the beast up, turn a couple of bolts, and swap them in? Is it really a $5K project to do it right? I had no idea. If this is the case, not a gonna happen.
I did the MKB 3.07 differential on my W208 CLK. It costs about $3,500 and efinitely requires some expertise with ECU tuning. It was fine before I got the Kleemann SC, however, once I got SC, it was occasionally bouncing off the rev limiter in 1st and 2nd gear. We are considering going back to a stock differential for the 6.3 liter conversion. Personally, on a C32, I would spend my money on getting more power, not swapping the differential.
easy there borris...
Originally posted by schwarzwagen
LOL.... that was fun wasn't it. How about the steering gear they couldn't center properly, that I fixed in two seconds?
There is a small difference but my quote of 120 is clearly a bit off! And yes your gearing is very very short. Got to love 4k rpm at 80 mph on the freeway! You need a 6.0L Hammer motor with your 3.46!
C32 is fine with its 3.06...a 3.27 would be nice but not for 5k !
