just got toyo t1s
Old Apr 29, 2004 | 08:54 PM
ardy6931's Avatar
c32
just got toyo t1s
Hey everyone, went with the majority advice and got the toyo t1s put on my ride. I like them so far but was wondering what tire pressure i should set them to. Any suggestions.
Also i want to get a wing, and rear bumber, harris told me lorinser doesn't use good quality parts so what are my other options. Anyone have pictures of brabus' rear bumber and wing?
Old Apr 29, 2004 | 10:29 PM
smgC32's Avatar
45 psi hot.
Old Apr 29, 2004 | 11:22 PM
Harris's Avatar
Re: just got toyo t1s
I didnt say Lorinser doesnt use good quality parts, I said Lorinser parts are made by Fiberglass and if you compare them to AMG or Brabus where the latter two use Pur-R-Rim, Lorinser will not be as good as the other two. If you are comparing fiberglass parts only, Carlsson and Lorinser both made good quality parts.
Old Apr 29, 2004 | 11:55 PM
KompressorKev's Avatar
'14 428i M-Sport, '02 C32 AMG
i don't believe Brabus makes a rear wing. correct me if i'm wrong though, i'd like to get one if they make it!
Old Apr 30, 2004 | 12:58 AM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
For the T-1s on a lowerd C32 rock 35-38 too much pressure in those tires makes for bad tread wear and noisy tires. I go through a set every 6 months, pic is a T-1S Fire lol
Expression is ok for body kits
Old Apr 30, 2004 | 02:03 AM
smgC32's Avatar
38 cold should put you right about 45 hot in agressive driving for an extended period with ambiant air temp around 70-80 degrees. This is exactly where the tire pressures were today during a heavy driving session. Anything lower will just increase the understeer tendancies of the C32 and eat the front tires worse. Very little feathering on the Toyo's as compaired with other tire choices due to the rounded shoulder design and the 1.1 degrees negative you get with a lowered stance and camber correction bolts. 30-33 cold pressures will surely eat tires twice as fast on this car. The lower pressures produce a wider variance in tire temperatures.
Old Apr 30, 2004 | 02:06 AM
smgC32's Avatar
The advantage of figerglass over plastic is easy of repairability and weight savings, although they are more prone to damage with the same force exerted.
Old Apr 30, 2004 | 04:10 AM
ChefC32's Avatar
i believe there is a brabus trunk spoiler no? I could have sworn i saw it on a brabus c32.. possibly the member on here (c32brabus?) that sold his car? Don't quote me on this though..
Old Apr 30, 2004 | 08:54 PM
the one i believe on c32brabus car is the carlsson rs trunklid i think
Old Apr 30, 2004 | 11:12 PM
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
38 cold is based on the factory wheel? I have 9.5's in the rear, and I'm running 34psi. I do agree with the temps though. When they are hot, they aren't confidence inspiring...it's as if they're lazy, and then boom, they stick like glue.
...i'm still playing with the pressure to find my sweet spot...
Old May 1, 2004 | 12:41 AM
smgC32's Avatar
Not running stock. RENNtech 18x8.5 w/ 235 40 18's front, and 18x9.5 w/ 265 35 18's rear. Carlsson RS suspension ride height set at 13.5" front and 13.0" rear as measured from center of hub to fender lip. Depending on your driving style and road surface temperature, 38-40 cold is where you want to be on this tire. I had them at 33 cold when I first put them on and they exhibited much more understeer at this pressure. Never saw over 40psi hot with that set up. The Toyo's need more pressure than some of the other performance tires. Every compound has its own sweet spot as well as every car and every driver combination. Experimentation will lead you to the right set up for yourself which should be close to this recommendation.
Old May 1, 2004 | 01:51 AM
BenzoAMGpower's Avatar
Cars and boats!
smgC32, could you please send me a pic of how ur C32 looks with the 18" Monolites?? I would love to see how the 18s look compared to the 19" Monolites on the C32 i see rolling around the beach at times. my email addy is EuroJDM@bellsouth.net
Old May 1, 2004 | 12:18 PM
CHATMANR's Avatar
Veteran: Navy
'01 C320 SS
So you are 38-40 front and back? What are you running in the rear?
Old May 1, 2004 | 12:43 PM
smgC32's Avatar
It will depend on what valve setting you have selected front and rear, but generally the front pressures will be equal or greater than the rears. I currently have 38.5psi at all four corners.
Old May 1, 2004 | 01:30 PM
Zeppelin's Avatar
C32
Are the centers of the rear tires wearing in the middle. That pressure seems too high. I run the Toyo's 33psi rear and 36 psi front with very little understeer, then again I run the H&R rear swaybar and 245 fronts.
Old May 1, 2004 | 02:15 PM
Vader13's Avatar
Free Toyos for me. Zep that sounds about what psi I run.
pics are FZ4's and did not work well with the C32 power, also old system.
Toyo C32
Old May 1, 2004 | 06:43 PM
smgC32's Avatar
Of course you have less understeer in your set up. You are running 3psi higher in the front. I have no center tire wear problems with the Toyo's and had no center wear problems with the GSD3's which I wore down to 0/32's with the same pressures. It is all in the way you drive the car. If you are prone to drive heavy footed in a straight line from a stop, then you will most certainly wear out the center portion of the tire before the outsides with more pressure in the rear. Less pressure and a heavy foot will wear more evenly and will hook up better. I have no interest in straight line driving and prefer to think of a straight line as only a transition between corners. If you like less pressure in your tires for your own driving style, than that is were you should run them if it works for you. If you find yourself in the twisties on your favorite back road or on the track, lower pressures with this tire will most definately provide slower times
Old May 1, 2004 | 07:16 PM
ericktu's Avatar
W211
Re: Re: just got toyo t1s
uh isnt lorinser made out of strong poly eurothrane not fiberglass?
Old May 2, 2004 | 11:20 AM
cincyc32's Avatar
2002 C32
How is wet traction with the Toyo's? TIA
Old May 2, 2004 | 12:12 PM
CHATMANR's Avatar
Veteran: Navy
'01 C320 SS
They hook up and handle extremely well in the rain. That is based on me using them in rain falling at about 1/2 to 1 inch per hour. No hydroplaning 75-85mph. To date, the best performing tire hi-perf I've used before the T1-S was the SP9000...and that one is no slouch in rainy conditions.
Old May 2, 2004 | 02:55 PM
Vader13's Avatar
The T-1S work good in the rain on the C32.
The Toyo FZ4 are death in the rain on the C32
I just checked my pressure, Its been very hot in So Cal.
I put 33psi front 36psi rear 6 weeks ago.
It's at 25psi front and 30psi rear
Rear T-1S 265/30/19
Front T-1S 235/35/19
Brabus 19 9.5 rear 19 8.5 front
Old May 3, 2004 | 01:23 PM
CynCarvin32's Avatar
Mercedes Benz
First hand review...
Since SMGC32 and I are trying to make his car into a want to be BMW (goes fast and turns well -- this was a joke FYI) I took the car out for testing last Friday and I learned a bit about how it drives and feels. I drove my favorite section of road for 2.5 hrs straight and put 80+ miles of canyon driving on the tires.
Last time I drove the car it had 35 psi at all 4 tires and the car felt terrible. No grip, wiggled through each corner, and generally felt dangerous. At that point Steve and I both wrote the tires off as being terrible but we stuck with them and played with the pressures to see what would happen.
The T1-S is known to be terrible at low pressures. While some tires like 35 psi this tire needs to be at 44-45 when you are running hard to feel proper. At these pressures, the car was extremely neutral (don’t forget the Carlsson RS Kit) and the grip was nearly equal to the GS-D3 (but not quite). Tire wear is extremely even (1.2 degrees negative camber front 1.7 rear) and the car felt better than any C32 I have driven to date (my old car included). I have never felt a MB NOT understeer the way this car did. The car drifted and would rotate instead of plow. I had to change my driving style to compensate for the change in dynamic and I really enjoys the ability to power out of corners without the front end washing out.
Great car. The C32 can be set very well but AMG chose to go for comfort and safety. A few parts and well that characteristic is GONE!
Old May 3, 2004 | 07:11 PM
Zeppelin's Avatar
C32
Cyn,
Did I hear you right. You are satisfied with the C32 suspension setup on SMGC32's car. I did not think I would ever hear those words from you Now you guys need to experiment with brake pads and see if you can get the brakes to your liking.
Old May 4, 2004 | 02:09 AM
Mercedes Benz
Well I can see where you are coming from Zep..
I may seem like a ultra picky crazy man but I am not unrealistic. Clearly I have a reputation of being an irrational ***** on this board but frankly I think I am just a car nut who likes to discuss how cars drive. Maybe I just come across as being nuts...who knows.
The Carlsson RS kit did help steves car a great deal. The shocks seem to be a big help but it is still not perfect. We may try a different suspension set-up but this just shows how crazy we really are. With time we will have the car set and then everyone else can just follow in out foot steps and have the MB that beats the M3 at its own game. The Carlssons were set at 7 front and 8 rear (9 being the softest) and I feel it was a bit soft. Steve enjoyed the smooth ride on his 20 mph drive to work but in the hills it could use more stiffness (but still worlds better than stock). I will take the car out next week for some testing at 5 front and 6 rear to see how that feels.
But yes I do love his car now. At times I want my C32 back so I could put all the same parts on it and make it what I always wanted it to be. Trouble is my car had so many issues that it was not worth keeping. I always knew the C32 had a good chassis but it needed some better suspension parts to get there. Steve may do a rear subframe upgrade and put in some new bushings and if so, this car will truly be unstoppable. With this firm suspension you can really feel the bushings deflect and this makes the car feel skittish at times (under braking from 130 -- at the big track -- Steve said the rear was all over the place and the subframe kit fixes this issue).
As for the brakes...stay tuned...we have that issue being solved as we speak. Fade will be a thing of the past sooner than later!
So when will you come up to Malibu for a drive? Good weather these days so its driving season once again!
Old May 4, 2004 | 01:05 PM
Zeppelin's Avatar
C32
Re: Well I can see where you are coming from Zep..
You really wan to see how the poor mans C32 runs
Send me an Email if you want to meet in the canyons one of these days. I have business in Van Nuys(not to far from the canyons) I can attend to M-F, so it could be during the week or Saturday/Sunday works as well.
