Lightweight brake components for C32
To repeat:
First of all, it is a French surname of nobility, and is pronounced "Vom-eee"
My first name is "Toulousse"
nestle tollhouse?
The Brembo shaves off 13 lbs on each front corner. The total is a savings of about 26 pounds unsprung. I think that if you change the the rears out you will probably get another 10 pounds on that but I am not sure.
The limitation of the kit is that you need to have at least 18" wheels because it is larger than the stock brake kit.
I have one that I purchased a little while back and I am probably not going to be putting them on my car. It is brand new and still in the box - never used. I need my car in the winter and I don't want to buy another set of 18" wheels for the winter just to accomodate the brake kit.
PM me if interested.
Prasith
Not sure if anyone else watch Sports Car Revolution on Speed Channel, they are doing a build up of an Acura RSX and installed a big brake kit from StopTech. After install they dyoned the car and lost 12hp to the wheels. I thought the stoptech kits were light weight, but guess I was wrong. Of course the larger rotors also contribute to the HP loss.
