Genuine MB trans fluid or Shell ATF 134/ FUCHS 134?
I was reading some old posts and saw some member upgraded to a better fluid for the 7 speed autos and saw no problems other than some people experience shift delays or lighter feel if that even is a problem.
I don't know what fluid is currently in it so my gut says to go with the genuine fluid because of how sensitive transmissions can be to different fluids. What do y'all recommend? Shell atf is under 10 a quart and double for the mb fluid.
I did do some research when changing my trans fluids and found the new 7 speed blue fluid is backward compatibile to the 5 speed red fluid.
I have not installed the blue 722.9 fluid in the 722.6, but I have a dozen quarts ready when needed.
Currently have both MB label (they don’t make their own), and Fuchs used in my 5 speeds I’ve changed. No issues.
Only have used MB label in my 7 speed as they are fragile compared to the 5 speed, and it was still under warranty.
there has been a lot of people saying the new fluid is giving them problems.
ill do a bit more reading before I get the fluid but it does seem like the ones for the 7 speed have mixed reviews. Thanna again
