Need C55 catalytic converters!
Old Mar 6, 2019 | 08:26 PM
Timmy121's Avatar
2005 C55 AMG
So my drivers side catalytic converter is going bad and in need of a new one but figured i should just replace them all because of age anyway. Dealer quoted me $4,008.63 for both sides and i don't like that price. Hate to ask but any aftermarket that will work just as good or better? bolt on preferred but welding is fine.
Thank you all in advance!
Old Mar 6, 2019 | 09:43 PM
rilonprime's Avatar
2005 C55 AMG
Primary or secondary cat? Our cars have 4 in total. You could just delete it and reap some power gains
Old Mar 6, 2019 | 10:07 PM
Fantomas's Avatar
2006 ML350, 2005 C55, 2004 E55
Need a new one because it's throwing a cat efficiency code or because it's clogged and the car is misfiring badly?
Old Mar 7, 2019 | 08:16 AM
Benzaddict32's Avatar
C32x2 RIP, 2005 C55, 2020 GLB 250, 2014 E550
I recently had my primary cats replaced with a pair of magnaflow universal cats. My passenger side cat had been rattling for a few months and I had finally had enough. I believe I paid less than a $100 for the pair. It’s been about 2,500 miles since and so far so good.
Old Mar 7, 2019 | 01:42 PM
alboogiee's Avatar
I would suggest to start with replacing your post cat o2 sensor(s).
Old Mar 7, 2019 | 08:43 PM
Timmy121's Avatar
2005 C55 AMG
Not sure but i got the code P0422 - power train - Main Catalyst Efficiency Below Threshold (bank 1)
I think its from changing my headers because it was after that and my tune when it started, i get a nice pop/popping sound now in my exhaust when i downshift or hit 4k+ RPM and let off the gas (blow back?) sounds nice!
Old Mar 7, 2019 | 08:45 PM
Timmy121's Avatar
2005 C55 AMG
throwing a cat efficiency code. think its from changing my headers and Dyno tune
Old Mar 7, 2019 | 08:47 PM
Timmy121's Avatar
2005 C55 AMG
I don't have any rattling sounds or anything like that, starting to wonder if its just my Tune and new headers causing the code but yeah that's a really nice price! i was looking at the magnaflow, bolt on or welding tho?
Timmy121's Avatar
2005 C55 AMG
That would be a good start! would you happen to know the part numbers?
Old Mar 7, 2019 | 08:57 PM
Timmy121's Avatar
2005 C55 AMG
If i were to remove both primary Cats would i pass emissions (Maryland)? and how could i keep the car from giving me check engine light with the cats gone?
Old Mar 7, 2019 | 09:30 PM
Fantomas's Avatar
Before you waste a ton of money on unnecessary parts I would suggest that you invest in some oxygen sensor spacers for your secondary o2 sensors. They are about 6 bucks a piece and are my go-to method when dealing with cat efficiency codes.
Old Mar 8, 2019 | 07:29 PM
Timmy121's Avatar
2005 C55 AMG
Could you link me to spacers? i founds tons but not sure what would work with the C55? all the same sizes?
Old Mar 10, 2019 | 09:45 PM
Fantomas's Avatar
Most oxygen sensors are the same, 18x1.5mm.
I'm not sure about clearance on the C55 but these ought to do it.
https://www.ebay.com/itm/O2-oxygen-s...ss!97080!US!-1
Old Mar 11, 2019 | 09:51 PM
Timmy121's Avatar
2005 C55 AMG
Great! i picked these up from advance for $8.59. says spark plug fouler but guy told me its the same thing? gonna try to get them in this week
Thanks!
Old Mar 13, 2019 | 05:08 PM
AtlasMG's Avatar
2006 Mercedes-benz C55 AMG
You said you changed your headers with OEM or performance because if you got performance headers your tuner should have tuned the code out because I plan on getting Kleemann headers and they delete the primary cats and with a tune the check engine light goes away.
