Surveying Air Pump problems of C32
Old Jul 7, 2004 | 11:25 PM
ToreRITO's Avatar
2002 C32 AMG
Just wanted to check out with everyone about their experience after the typical failure of the Seconday Air Injection Pump inthe C32. After researching older posts, I found out some people had the controller module replaced with the Air Injection Pump also. I just had the Air Injection pump replaced but not the module.
I know this is a typical problem with this car, so my question is:
Who has had this pump replaced but not the module and experienced no further problems.
or
Who has had this pump replaced, continued to have problems and had to eventually replace the damn module also.
Your opinions would be greatly appreciated.
Torerito
Old Jul 8, 2004 | 09:22 AM
DL_AMG's Avatar
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
I'm not one of your option but...
I had both Pump and module replaced. No problem so far.
Old Jul 8, 2004 | 10:48 AM
acm's Avatar
acm
'02 C32 AMG
I had my pump replaced twice, until the dealer realized that the problem was with the control module. Finally had the pump and control module replaced the third time.
Old Jul 8, 2004 | 06:51 PM
Peench's Avatar
2002 C32 AMG
A little over a month ago I had the air pump replaced in my car when it continued to run after the car was off. I had to disconnect it to get it to stop.
A month later it did the same thing. They replaced the pump again and said that a relay switch was stuck open so they replaced the switch.
It has only been about a week or so since then so we'll see if it dies on me again. If so, I'll tell them to check the module and replace that as well.
Old Jul 8, 2004 | 07:37 PM
IdriveFast's Avatar
C32 AMG
how do you know if the air pump is damaged?
Old Jul 8, 2004 | 11:15 PM
ToreRITO's Avatar
2002 C32 AMG
I got the check engine light...thats all i could notice....also a wierd smell when I accelerated, but not sure if it was due to the pump failure
Old Jul 9, 2004 | 02:13 PM
RapidG's Avatar
C32AMG
Yup, I had the pump replaced, and then about 2 weeks later (CE light on again) replaced the module.
Old Jul 13, 2004 | 04:11 PM
Peench's Avatar
2002 C32 AMG
Mine stayed on when I turned off the car. The first time it did it, I thought there was a cesna airplane flying right above my car. I popped the hood, and it smelled like it was burning. It didn't turn off for about 15 mins after I turned off the car so I disconnected it.
Old Jul 14, 2004 | 02:02 AM
VancouverC32's Avatar
C32
Mine is currently in the shop waiting the pump to be brought in. I will make sure that they replace the module as well. What other symptoms other than CE light were there?
Old Jul 14, 2004 | 08:33 AM
ToreRITO's Avatar
2002 C32 AMG
I could not find any other symptoms other than my air pump spinning like crazy when the car was turned off. I guess until it died.
Old Dec 8, 2005 | 11:50 AM
Renault78law's Avatar
2003 C32
i got a check engine light the other night.
dealer replaced both the airpump and module.
Old Dec 8, 2005 | 12:37 PM
rrf's Avatar
rrf
When the relay fails it will usually kill the pump, and it does it quickly. It is actually the relay's fault. The relay overdrives the pump, and it can't handle continuous use for very long.
Dealers like to be pig-headed and replace them both after the pump had been murdered.
I believe that the original relay design has been fixed and the newer model is more robust.
The relay is about $15 and the pump is $150, dealers are not too clever on this one, maybe they like to inconvenience the customer and make a few $.
If mine hadn't already been done I would pay the $ out of pocket and replace it myself. 2 minutes and $15.
Old Dec 8, 2005 | 01:18 PM
Vadim @ evosport's Avatar
C32 AMG
Both, twice.
Old Dec 8, 2005 | 01:21 PM
Bux's Avatar
Bux
G
never had this problem
Old Dec 8, 2005 | 01:41 PM
SiLvaC32's Avatar
C32
i had the problem too... replace the pump.
Old Dec 8, 2005 | 05:36 PM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
I had this problem, I didnt know it was covered under warranty so I bought a new pump and relay.... When I have my car service I'm gonna put the old pump back to have them replace it.
Old Dec 8, 2005 | 06:28 PM
Zeppelin's Avatar
C32
Trekman - Does the relay look like a different part than the original. Trying to find out if MB has improved the relay or it is the same one that is going to fail again after so many miles.
Old Dec 8, 2005 | 11:43 PM
Trekman's Avatar
same maker I think its made by tyco... if you replace the pump I would replace the relay the same time.
Old Dec 9, 2005 | 12:35 AM
smgC32's Avatar
only once so far. Thought it was going to blow up and catch fire with all that noise going on. Just unplugged it and had it replaced. Lasted 25,000 miles.
Old Dec 9, 2005 | 07:54 AM
Dead Ringer's Avatar
02 C32R
this is EXACTLY what happened to mine about 3 weeks ago, had module and pump replaced.....
