When removing the IC pump...
Old Oct 17, 2019 | 04:45 PM
Vette Moto's Avatar
Kleemann C55, C32
If I remove the intercooler pump without draining the coolant from the radiator or anywhere, would coolant free flow out once the IC is removed from the car?
Because I just removed the IC pump and barely saw more than 5 drops of coolant coming from the tubes. Does this suggest a blockage of sort further upstream?
Old Oct 17, 2019 | 06:55 PM
RPB's Avatar
RPB
I’m pretty sure a good amount should leak out; I believe it’s connected to the main coolant supply. My original pump was swapped out a few months back along w/ a coolant flush.
Pls don't take my word on this though. My first car w/ an SC, I can tell you this much the new pump made it run like a different machine.
