Help with front body parts of C55
Old 06-05-2020, 03:44 AM
Slava30490's Avatar
W166 ML350 BLUETEC, W203 C55
Originally Posted by C55er
I remember that the hood latch (safety hook) is different. The 203 (C55) has a PN A 203 880 03 64 while the 209 (CLK55) has a PN A 219 880 00 64. The latching bar on the front stiffening panel is the same. It could be fitment as one poster above said.
And it is also correct that the 203 hood has the studs for the chrome insert mounting. You also have to have the standing ornament as the 209 has the flat emblem.
Thank you, just received the trim and checked the latch. It might be need to cut some plastic inside of silver trim because the original latch is difficult to find and as per my suppliers it is not available in Europe...
Standing star is installed)
Old 06-05-2020, 06:24 AM
Design4111's Avatar
W203
Originally Posted by Slava30490
Yes, thanks. Probably will be easy to weld part of the bolts. I do have some holes in the hood but they are differs that studs supposed to be...
If memory serves me correctly, you are required to drill hole and fit the sleeve. You need some sort of rivet gun (could be a normal gun that you buy at hardware store, not sure) which collapses the sleeve inside the hole.
If this is correct (not sure), than you do not have to weld or glue or .....
Quick Reply: Help with front body parts of C55
