2003 C320 (W203) Engine Mount Issue
Old Jul 17, 2021 | 06:53 PM
MB87107's Avatar
97 E320 W210 Chassis
Hello and thanks for listening/reading.
Firstly I have learned a great deal from these forums and truly appreciate all of the knowledge I have gained (and money I have saved doing my own maintenance).
My girlfriend has a 2003 C320 W203. SHe had it in the shop for a maintenance recall (from an indy: bad new fuel pump) and the mech mentioned she really needs new engin mounts.
I was able to do the passenger side in about 40 minutes but the driver side is a U$%^I!!! nightmare. I have seen posts where you need to drop exhaust so I have a couple of questions on that especially since I am using ramps and crawling underneath:
  • Is it necessary to remove the O2 sensors or can you just disconnect at the connectors? The front O2 sensor looks a bit problematic to remove and put back on due to access. The mounts kit from FCP euro included 2 exhaust bolts and ringed metal gasket for exhaust.
  • How far back do you need to continue removing exhaust before you can start on engine mount? Does dropping exhaust mean removing the entire exhaust (to tailpipe)?
  • Are there any other options in getting to the top bolt? I have seen some people say to take out the compressor but I do not know how rugged the hoses are to be moving it around and I didn't see any exploded diagrams of A/C compressor removal.
  • Is there other maintenance to be done or items inspected while I have either the compressor or exhaust removed?
I will say that my w210 E320 engine mounts were a breeze...70 minutes and a couple of scratches on my arms.
Sorry for the all of the questions, just want to get this rectified. According to the data card the engine is 112946 31 325493
Old Jul 25, 2021 | 12:25 PM
steverwrx's Avatar
'03 C32, '14 Durango R/T, '10 Touareg TDI
I did the mounts a few years ago on my C32 when I added headers. Not too difficult. You must have one of these:
Amazon Amazon
to get the top bolts out on both sides. Disconnected and dropped just the front part of exhaust at the manifolds. I do not remember if I removed the O2 sensors or just unplugged them. Good luck.
