c55 advice need
Old Aug 4, 2021 | 05:37 AM
OZMERC's Avatar
CLK55
c55 advice need
Hi PEOPLE, I need some advice on purchasing a C55, I am currently looking at 2 vehicles one is a 2007 model with the 7 tronic gearbox and 120,000 km and the other is a 2004 with the 5 tronic and 126,000kms . Both cars have full service records and appear to be well looked after. From my reading and research it appears that the 5 tronic is a more reliable option, "Am I correct in thinking this ?" as I want reliability. Also, what should I be looking out for when comparing these two vehicles. The price is the same for each car. I just want a Sunday driver . Thanks
Old Aug 4, 2021 | 08:47 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
The c55 was only made in 05-06 and only came with the 722.6 5 speed transmission.
Old Aug 4, 2021 | 11:01 AM
PJmak's Avatar
Id love to see these 2004 and 2007 c55s
Old Aug 4, 2021 | 01:31 PM
cm60k's Avatar
04-11 SLK55 is the only (M113 5.4L), with 7-G.!,
i know a guy, who took everything from donor cracked 07 "SLK55", and put it on his "W203",,
Now his smile flows everywhere..
-;-ZAYED-;-
Old Aug 4, 2021 | 05:07 PM
amgen's Avatar
C55 AMG T with Kleemann K2 and some stuff: 414 hp and 562 Nm :-)
Smile
The C55´s were produced in Germany between late -04 to early -07, and always with 5 gear automatic.
Sold in North America 05-06, but only sedans.
F1 Special Edition (400 hp) was sold only in Germany.
Total amount produced (sedan, estate, SE) was approx 4.600.
SLK 55 Black Series had the same engine as the F1 Special Edition (M113 EVO with some extra stuff as headers etc).
Old Aug 5, 2021 | 09:40 AM
insame1's Avatar
the c55 sold in 04 was a w202. not a w203.
Old Aug 5, 2021 | 09:52 AM
cm60k's Avatar
If i'm not mistaken;
A) W202 from (March/1993) >> till (July/2000).
B) W203 from (July/2000) >> till (Oct/2007), and coupe with station wagon till (Nov/2011).
-;-ZAYED-;-
Old Aug 5, 2021 | 02:58 PM
amgen's Avatar
Total number of C55 AMG´s built (W/S203): 4.616
Number of Sedans built: 4.021 between May 2004 and February 2007
Number of Wagons built: 595 between May 2004 and May 2007
Number of imported Sedans to North America: 1.750 in 2005 and 2006 (no wagons)
Old Aug 20, 2021 | 04:36 PM
duke749's Avatar
C55 AMG
Old Aug 20, 2021 | 05:28 PM
cm60k's Avatar
Ah, that's interesting, i didn't see 2007 C55 before.!!,
is 2007 C55 comes with U.S version..!?!,,
AFAIK; MB replaced C55 >>> W204 C63, isn't..!?!?!
-;-ZAYED-;-
Old Aug 20, 2021 | 11:18 PM
skullbox15's Avatar
2014 C63
If the mileage is nearly the same, take the newer car.
Old Aug 21, 2021 | 10:18 AM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
There is not a US 2007 Model with 7 speed trans, or any 2007 US model.
Old Aug 21, 2021 | 11:11 PM
Benzrider17's Avatar
C43 c55 C63
Post some pics of both c55s so we could see color and condition
Old Aug 21, 2021 | 11:27 PM
duke749's Avatar
C55 AMG
https://www.vindecoderz.com/ go to this website and enter your VIN chassis number it will tell you which factory your car was assembled in
which market it went too , build sheet like special orders like a 7 speed gearbox .
Old Oct 27, 2021 | 06:23 PM
OZMERC's Avatar
CLK55
Question paddle shifters 2007 C55
Thanks everyone. I went with the 2007 C55 and yes they are all 5 speed, I am new so will ask a few questions from time to time. Does anyone else find the paddle shifters slow and laggy. These shifters on my 2007 were apparently factory fitted. cheer
Old Oct 28, 2021 | 10:27 AM
PJmak's Avatar
Theres no such thing as a 07 c55 in the United States. That's a guarantee
Old Oct 28, 2021 | 07:55 PM
OZMERC's Avatar
CLK55
Hi PJ mak the car was released in july 2006, but in Australia it is listed as a 2007 c55 cheers
Old Feb 11, 2022 | 02:30 PM
BlackMerry's Avatar
G55AMG, 500SEC, 500SEL, 380SE
-;-ZAYED-;-
ZAYED,
I am planning to built a M113 engine in my w460 G class.
class.
I will also take the interior (seats), dashboard and instrument cluster.
I'm considering 3 options as donor vehicle.ML55 amg pré-facelift (before 2002) W163
  • Engine: M113 5.5
  • ECU: Bosch ME2.0
  • Transmissie: 5G 722.6
ML55 amg facelift (after 2002) W163
  • Engine: M113 5.5
  • ECU: Bosch ME2.8
ML500 (W164)
  • Engine: M113 5.0 (eventually upgraded with a m113 5.5 amg engine afterwards)
  • ECU: Bosch ME2.8
  • Transmissie: 7G 722.9 (internal TCM)
​​​​​​Its hard to find a cheap facelift ml55 amg for parts.
Pre-facelift with ME2.0 are cheap.
Also i found a cheap ML500 w164.
I like the 7G transmission and the modern instrument cluster look of the w164.
What would you suggest as a donor vehicle considering my whishes?
I know that tuning/programming the ME2.8 is easier then ME2.0.
​​​​But the 7G transmission from the w164 is harder with software tune/programming then the 5G. (Speed sensor removal for example)
Hopefully you can help me.
Many thank from the Netherlands!!
Old Feb 11, 2022 | 10:13 PM
Fidel_CashFlow's Avatar
CLK55
Originally Posted by BlackMerry
ZAYED,
class.
  • Engine: M113 5.5
  • ECU: Bosch ME2.0
  • Engine: M113 5.5
  • ECU: Bosch ME2.8
ML500 (W164)
  • ECU: Bosch ME2.8
From my knowledge, I recommend ML55 facelift.
it has the engine you want, tunable ECU, (The 2.0 is very difficult to tune or to find a tuner most people running that would switch to the 2.8.) A solid trans. The only thing is, I would highly recommend getting a tcu tune to add some pep to it. Zero cat is very good! I hope this helps man and good luck
Old Feb 12, 2022 | 01:25 AM
BlackMerry's Avatar
I can even go for the w164, and after a while able to swap the 500 engine with a 55 amg engine .
Then i got both advantages of engine 55amg 2.8 and 7G transmission.
Maybe its too hard to get the 7G to work properly without limp mode if different sensors are not there?
Old Feb 15, 2022 | 01:32 PM
BlackMerry's Avatar
Is it even possible to swap out a ME2.8 500 engine to an ME2.0 55 engine? I can imagine that the me2.8 needs another 55 file. But do hardware things also match on those engines?
