Porterfield Pads
Old Sep 14, 2004 | 04:28 PM
AaronC's Avatar
C32
Porterfield Pads
I tracked down the PNs for the R4S pads, and they are: AP847 (Front) and AP603 (Rear). Does anyone have these pads? How are they? What retailer did you get them from?
Old Sep 14, 2004 | 09:40 PM
AaronC's Avatar
C32
Anyone?
Old Sep 14, 2004 | 09:44 PM
BenzoAMGpower's Avatar
Cars and boats!
tried them on my ML55, they kinda squeel a little after you put some miles on them!!!
Old Sep 15, 2004 | 12:31 AM
JohanG's Avatar
R4s
Had the R4S' installed up front only about 7,000 miles ago. Bought them from Jerry at www.myroadster.net. I'd say that they are noticeably grippier in an extreme braking situation. I don't track the car or drive the car hard enough for long periods of time to comment on the performance of the pads in real heated conditions.
I can tell you that the amount of brake dust up front has considerably decreased. Its a great change of pace to clean your front wheels once every week or two instead of every other day.
Johan
03 C32
03 SL55
Old Sep 15, 2004 | 09:51 AM
Cars and boats!
Johan
03 C32
03 SL55
any squeeling at all? They squeel a bit on my ML but i dont know if it will on a much ligher car!!
Old Sep 15, 2004 | 02:02 PM
Zeppelin's Avatar
C32
I have the R4s front and rear and don't notice any braking improvement over stock. They do cause much less brake dust accumulation on the front wheels, which may be there only strong point. And yes, they will occasionally squeal, not very loud and usually just the last 5 feet before the car comes to a stop.
If you only drive on the street and can live with the brake dust I would stay with the stock brake pads.
Old Sep 19, 2004 | 06:34 PM
derAMG's Avatar
time for my C32 to replace front brake pads... (24000 KM)
are they cheaper than OEM pads?
Old Sep 19, 2004 | 07:23 PM
AaronC's Avatar
C32
Heh, not quite:
$179 List fronts #847
$119 List Rears #603
Old Sep 19, 2004 | 07:30 PM
JohanG's Avatar
Had absolutely no squealing when I installed a set upfront only. If you order from Jerry they come with an an Anti squeal spray and or paste, along with (I believe) some paper to use on your rotors. I think that if you follow the directions in that kit and break in your pads properly, the chances of having brake squeal issues are pretty slim
Old Sep 19, 2004 | 11:27 PM
derAMG's Avatar
thanks AaronC just $30 of difference, maybe i will give it a try because it sounds more durable than oem
Old Sep 20, 2004 | 12:48 AM
SiLvaC32's Avatar
C32
heres a place i got my porterfield pads from:
www.supremepowerparts.com
they are quite cheap too!
