Wanted either a C32 or a c55 amg in Arizona for around 15k
I split my time between Phoenix and San Diego
For $15k, I'd really consider letting it go. That's a solid offer.
It’s in good mechanical shape- there are only 2 codes.
1. bad fuel level sensor
2. telematic doesn’t work
The following items was replaced- actual issue
1. alternator
2. all belts and fluids
3. new fuel pump- weak spot and replaced to the pump recommended by the forum.
The following were replaced because of cluster problem when it probably didn’t need to be replaced
1. Entire esp and abs pump
2. front and rear SAM module- new from FCPEURO
3. New battery
4. New key
The following was upgraded-
1. Factory bi-Xeon was retrofitted- because of 2002 C32 didn’t come with bi-Xeon- it will always have high beam warning on the dash.
Clean title and no accident.
The main issue that cause so many stuff to be replaced-
The original cluster has memory corruption and causing all sort of errors (ESP/BAS, display error, SRS fault, brake fault). After replacing all of the items- it continue to trigger stored code on to the ECU. My mechanic and I was finally able to get a replacement cluster and after clearing the stored codes. It’s working perfectly. To confirm it was cluster problem, we swapped back old cluster and it triggered the store code fault again.
The cluster is being send for repair. Should be back this weekend. I lost my storage space and also be moving to Japan soon for work. I don’t have time to keep my fleet of cars. So some of them have to go.
I am asking $6000. Which considering how much I have spend on it, I am already deep in red. I rather see it going to a good home.
the only other issue- front and rear bumper needs paint, door handle also need paint. Car has ceramic coating. The paint is in excellent shape.
