ASP Pulleys
Old 12-02-2004, 11:34 AM
  #51
Bobdole's Avatar
C32
Guys the ASP pulleys will work fine,with no problems,I have dynoed my car stock with 298 rwhp,and 284 torque.
With the ASP pulleys i got 309 rwhp,anf 308 torque,and this is without software,and Frankw,all the belts stay the same as you are going larger in one place and smaller in another,so it use the stock MB belt.I am waiting for Upsolute to tune ecu,i will keep u guys posted
Old 12-02-2004, 11:58 AM
  #52
jayitx's Avatar
2004 Capri Blue C32
+11hp and +24tq---not bad without the ECU done. If I got the same gains, I would be at 314hp and 322tq---I'd love that!!
Old 12-02-2004, 12:14 PM
  #53
Bobdole's Avatar
C32
If you guys look at Renntech website you will see the gains with pulleys and seperatly with ecu only.There numbers are true and not at all exaggereted,like many other place.but they rate their hp and torque at the flywheels not the wheels.Food for thought
http://www.renntechmercedes.com/pdf/W203.PDF
Old 12-02-2004, 01:41 PM
  #54
Zeppelin's Avatar
C32
Bob,
I think the pulleys will give you more horsepower than you registered if you splash in some 100 octane. I would bet that your dyno graph starts tapering off near redline. Compare your stock dyno to the ASP pulley one. They should be linear with the pulley one being higher. You will find hear in California in the summer you will not get full HP without some gas higher than 91.
Old 12-02-2004, 03:21 PM
  #55
MBworld Guru
FrankW's Avatar
white and whiter
nice to know
I'll definitely get this done in the future.
Old 12-02-2004, 10:45 PM
  #56
430
430's Avatar
SLK32
What kind of Dyno was used for the pulls, mustang, dynojet, dynopac, or? Can you please post your graphs.
Old 12-02-2004, 11:20 PM
  #57
Bobdole's Avatar
C32
these are off a dyno jet.These # are from my stock runs,the dyno sheet i have is to large to post,i cant make it small enough to post
2003 C32 AMG
•RuaFile_0Ot.drf Max Power = 292.78 Max Torque = 280.54
•Runile_004.drf Max Power = 298.53 Max Torque = 284.52
RunFiIe_006.drf Max Power = 295.53 Max Torque = 284.77
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Quick Reply: ASP Pulleys
