Baby's first......Dyno!
Old Nov 3, 2004 | 05:25 PM
jayitx's Avatar
2004 Capri Blue C32
I finally got around to getting my car dyno'd today. The only mod I have done is the SL55 full intake. Other than that it is stock (unfortunately). The numbers today were:
1st Run
Max Power = 303.2
Max Torque = 290.4
2nd Run
Max Power = 295.8
Max Torque = 293.0
3rd Run
Max Power = 303.6
Max Torque = 291.7
A/F Ratio stayed about the same throughout--roughly between 14 - 12. Are these all pretty good numbers? I'm looking at pulleys and ECU next.
Old Nov 3, 2004 | 05:29 PM
BenzoAMGpower's Avatar
Cars and boats!
what gear did you dyno in?
Old Nov 3, 2004 | 05:37 PM
jayitx's Avatar
2004 Capri Blue C32
3rd........using Dyno Mode.
Old Nov 4, 2004 | 01:19 PM
Cars and boats!
i have an 04 C32 also... how did you put your car into dyno mode??
Old Nov 4, 2004 | 02:20 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
that's one powerful C32 w/ only the SL55 pipes. I'm still looking to get this done...sigh.
Old Nov 4, 2004 | 02:33 PM
jayitx's Avatar
2004 Capri Blue C32
Someone here posted steps, and it worked for my car. Here are some notes I took while doing it:
Turn the key in Position 1 (not started);
Press the odometer reset button 3 times to enter the diagnostics menu;
Press the Up arrow button (left side of steering wheel) twice to scroll to the ESP Dynamometer Test screen;
Press the '+' button (right side of steering wheel) to turn it 'ON';
Start the car.
When the car starts, it will flash 'ESP not active', 'BAS not active', 'ABS not active' as a warning.
When I turned the car off, then on again it was still in Dyno mode so I had to turn it off manually ('W. Term. 15 OFF' (use the '-' button from the ESP Dynamometer Test screen)).
Hope that helps.......
Old Nov 4, 2004 | 09:53 PM
jayitx's Avatar
2004 Capri Blue C32
Questions for the experts here:
The first post in this thread shows my dyno results, including A/F ratio. Can anyone tell me if my A/F ratio is good or bad? If mine is not good, what's a good A/F ratio? I have the SL55 intake kit installed. If I install a pulley upgrade (before an ECU upgrade), how would that affect the A/F ratio as it is now? Sorry to make you guys think, but I obviously don't want to screw up my car and any help would be appreciated. Thanks!
Old Nov 4, 2004 | 10:32 PM
hantzis's Avatar
2004 C32 AMG
Your A/F is pretty good. You want to stay around 12-12.5 at the higher rpms. It could be a little bit lower at the 4,000rpm mark.
With Supercharged engines the A/F should be no higher than 12.5 at higher rpms -
With Normally aspirated engines, teh A/F should be no higher than 13.5 at higher rpms.
Your #s are good and strong. You can compare them with my 04 C32 stock dyno results - SAE corrected on a dynojet in 3rd (and dyno mode)
http://dynoperformance.com/search_details.php?ID=756
Old Nov 4, 2004 | 10:34 PM
IdriveFast's Avatar
C32 AMG
how much did the SL55 y-pipe and the installation cost you?
did you do a baseline run? before you installed the intake pipe?
Old Nov 4, 2004 | 10:36 PM
hantzis's Avatar
2004 C32 AMG
Start the car.
Yep, BTW - I believe in the 01 and 02 C32s you need to hold the reset button in for 30 seconds or so instead of pressing 3 times. Glad they changed that!
Also, when we dynoed a 03 CL600, the same exact steps work to put the vehicle in Dyno Mode. I'm sure the same goes for other 03/04 models
Old Nov 4, 2004 | 10:47 PM
JLee81's Avatar
04 CLK55, IWC CLS55 AMG(one of 55), 07 Honda CR-V 4WD
the result is somewhat inconsistent. There shouldn't be 8 hp gap in between the runs. with in 1 hp margin is generally acceptable. Next time, ask the guy to do it until 3 consecutive runs are close to each other.
Old Nov 4, 2004 | 10:48 PM
jayitx's Avatar
2004 Capri Blue C32
My brother-in-law owns a body shop, so I had him get the SL55 parts for me. I tried to order them through a dealer and they wanted almost $600, but my brother-in-law got them for me for around $300. I installed them myself...it's pretty easy. It took less than 1 hour. I just recently switched to K&N air filters too.
Unfortunately, I didn't dyno it before I put them in. But when I bring it to the dealer for service, I put the originals back in so I could dyno it in stock form.
Old Nov 5, 2004 | 12:13 AM
Cars and boats!
any reason for you to dyno in 3rd gear instead of 4th gear? Also, did anything weird happen before/after you put ur car into Dynameter mode? My check engine light came on after i was ummm "messin around" with the car on Dynameter Test Mode.
Old Nov 5, 2004 | 01:30 AM
BoBcanada's Avatar
AMG
Thats WHp right?
Old Nov 5, 2004 | 02:03 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
a/f ratio looks good... yeah, it should be whp. nice broad torque band!
n/a cars should give very consistent runs... witnessed a bmw 540i do 3 consecutive runs within 1 hp of 240 whp. 15% loss on auto tranny, very nice.
i also know turbo cars can be a ***** to run on dynos...with quite a difference if there isn't enough cool air... heat soak in ic can be a problem..
i wonder if same thing happens on sc'd cars??
Old Nov 5, 2004 | 10:20 AM
cobraq8's Avatar
02' C32 AMG
To me, your Dyno A/F ratio graph looks very to similar to mine, however, my HP/TQ was just little higher
Old Nov 5, 2004 | 10:45 AM
hantzis's Avatar
2004 C32 AMG
The variation in hp is expected. Nothing wrong with you car here. Heat soak affects supercharged/turbocharged engines. Even with Normally Aspirated vehicles I've seen variations of 4-5wHP on the dyno.
Here is a 3.4wHP variation on 2 dynoruns back to back - on a N/A Cobra:
http://dynoperformance.com/compare_d...D1=405&ID2=406
Depending on temperature, humidity, engine temp, etc, the hp/tq will vary from one dyno run to the next. Nothing to worry about
