C55 Resonator Removal
Otherwise, I am quite comfortable about this.
BTW, where is the resonator located?
No, the car will never be that loud with just the resonators removed. It will still sound "Mercedes". :p It should be heard in the cabin when you are curusing. Maybe just under acceleration.
The resonator will give you a couple of HP but nothing to write home about. There will be no issues with the ECU, even if it could not compensate.
Sorry I am a car mechanics idiot.
Is the silver " cooling fan like " component sticking out in the bottom of the car the resonator ? I noticed this 'thing' long time and don't know what it is. And, why I never saw them in other cars I owned?
cnt
This causes less resistance to exhaust flow and should give you lower exhaust gas temperatures (good for lots of things in your car), lower backpressure and subsequently more horsepower (or engine efficiency).
I hope this helps you out some. As far as I know the purpose of a resonator is to further muffle sound and to change the frequency of an exhaust gas pulse so that it does not "resonate" (vibrate) with the vehicle and cabin. Some poorly designed exhaust systems cause very annoying vibrations to enter the cabin and are generally unpleasant to our ears. Resonators are generally employed for this to my knowledge. If anyone has a better explanation or has heard otherwise, then speak up. There is exceptionally low amounts of information about resonators published.
So the " silver thing with fins " I saw sticking out from the bottom of the car is not the resonator but it is the differerntial (what ever it means).
Since as now saying the removal the resonator will give more unpleasant sound but better horsepower/performance, I would probably not need to do it as I do not go to tracks. It may be tempting to get a deeper exhaust sound than my C55's present form, I would stick with the original for a while.
Wow. A lot of information here. Thanks.
cnt
i am glad they didn't just free up as much backpressure as possible in the gain for bragging rights as the freest flowing system, but i think it's a nice addition to the c32. i definitely don't think it hurt performance at all, so i would guess eisenmann is right?
Ahhh, that explains it. The removal of your cats is what caused the 'issue' (your loss of low end torque).
As far as the whole not enough back pressure and loss of torque thing. There are 2 different camps on this issue. One side feels that there is no such thing as too little backpressure and the other feels that a certain amount of back pressure is needed to maintain low end torque.
. all false if you gut ur cat thats will kill power, if you replace your cat with oversized pipes that could also. but if you use the same stock piping size ur fine. i did it with my ls400 and it is night and day difference.
so in essence remove your 2 rear cats the ones w/o the o2 senor behind it. and/or your resonator you will notice a difference. sound mostly with resonator, if you do the rear 2 cats you will def. gain some power and be legal. 2 cats is plenty.
Ahh help me please!
